Question about Electronics - Others
Usb Drive I have a usb drive that has stopped working is there any way to retrive the data.
    Problem Solver:
  • 12 Answers
Two questions for ya:
A) When you say USB drive, do you mean an external CDROM, DVDROM, or mechanical HARD DRIVE or do you mean a FLASH DRIVE? (see below)
B) When you say "NOT WORKING" do you mean that when you plug it into ANY USB port, you get an error tone; you don't get any response; you see the drivers being loaded, but no drive appears; you see the drive appear, but no files are listed on the drive; or something else?
From these two questions, we will be much more able to help.
-jase
NOTE:
External devices that have mechanical moving parts, like CD and DVD drives often require external power sources in order for the drive to function. Even external hard drives can require a separate power source. This is because the small amount of electricity provided by the USB port is not enough to power the motors inside these external devices.
Another type of external storage medium is called a "Flash Drive". It is like a hard drive in so much as it stores data and appears in your explorer/Finder window like a hard drive. However, there are no moving parts, so it never requires an external power source.
Posted on Nov 29, 2007
SOURCE:
My external pc drive stopped working.i under stand the Head is broken, I want to retrive important data from it. External drive is a Ministation {Buffalo} P{lease help,
You should try mounting the hard disk internally since any external HDD is actually a normal HDD in a SATA to USB enclosure. If that doesn't work , you should try finding recovery experts in your area but that might be expensive!
Nov 01, 2013 | BuffaloShop Buffalo DriveStation Axis...
Retriving Data from Storejet and uploading to new computor
If the hard drive in the IBM laptop is OK then remove the hard drive from this laptop. Connect this hard drive to an USB hard drive adapter then connect the USB adapter with the hard drive into the USB port on the Vaio laptop. The Vaio laptop should see it as an external storage device (if the hard drive is OK). You can then open the various folders and files then copy these to the Vaio laptop
Jan 09, 2013 | Transcend StoreJet 320 GB USB 20 Hard...
Thank you for your reply. I wneed to retrive material from my hard drive and favorites list. What is the best way to do this?
Remove the hard drive and connect it to an USB hard drive adapterand then plug this adapter into a working computer's USB port. The computer sees this as an USB mass storage device (external hard drive) and youcan open the various folders and files, then you can backup your data.
Jul 21, 2012 | Medion Computers & Internet
I have lock my 4GB Micro SD card and yet to remenber the password so how can I retrive it ?
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, USB Memory Drives
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
hope this helps
Apr 13, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My external harddrive does not work after I dropped it
Unfortunately, that probably means it is damaged beyond help.
If the only problem is a damaged connector, like the USB port, then you could remove the drive and use and external USB adapter to continue using it. Or at least retrive your data.
Jan 19, 2011 | Computers & Internet
MT Hd just has a green flickering light now and dose not work with my computer how do i make it work again or retrive my data off it
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Nov 17, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
My Toshiba HDD2171 has stopped working. I have connected it to my Desktop PC with a IDE connector. It fails to be recognised. What can I try to retrive my data.
If you tried to setup the hard drive as a slave drive and it didn't work then you might try this, but I think it you will have much success.
Connect the hard drive to an USB hard drive adapter and then plug this into the USB port of a working computer. If this computer detects it as an external storage device and you can open the folders and files then you are in luck.
If not then there are companies that can recover data from faulty hard drives, BUT it will cost you an arm and a leg for their services.
Sep 27, 2010 | Toshiba (HDD2171) 40 GB Hard Drive
SYSTEM SHOWING THE EXISTENCE OF THE PEN DRIVE BUT WHENEVER I AM TRYING TO OPEN IT , IT REPORTED THAT THE PEN DRIVE REQUIRED TO BE FORMATTED. I HAVE FULL OF DATA OF THE SAID DRIVE.
use any data recovery software like easus data recovery and retrive ur data...then format ir...
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
Aug 13, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Electronics - Others Logo
200 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
