Question about Canon imageRUNNER 400S Copier
Canon 330s Copier with Dark printouts
I believe that the image drum may be causing the dark printouts, please confirm this and if possible supply a replacement part number?
If there may be another part that causes the issue please do not hesitate to let me know.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
How dark is it??
canon is sensitive to dust,
turn off machicne take off top copy glass move scanning glass and wipe with a clean towel.
try adjusting the dark and light does it change? if it comes out better on light then the drum is the problem. ( getting old)
Posted on Nov 30, 2007
PRINTOUT OVER DARK
Was the image unit replaced? if remove and reseat. Check the charge corona assy. while the image unit is out the assy. sits above the drum.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 13, 2014 | Minolta EP1030/1030F CS/PRO Copier
Black smudges
that is the life time of drum is over. you must change it
Dec 29, 2011 | Canon ImageRUNNER 330s Copier
Need steps in removing old toner from canon image runner 330S copier
open front cover, release developer lever at right,release feeder lever at down right corner,unscrew the centre screw at the top of the drum unit, slide out the drum unit, at the back of unit u will find a clear plastic cap remove it and empty the waste toner reverse all the process to place all togather.
Jan 04, 2011 | Canon ImageRUNNER 330s Copier
I HAVE DEGITAL COPIER IR 1600 THE PROPLEM COMING IS BLACK COPY IN REAR SIDE PLEASE HELP ME
it is very possible the dark line on your copies are being caused by the drum. it will all depend on how many copies are on it but without seeing one of the copies the best guess i can make is the drum.
Jun 10, 2010 | Canon ImageRunner 1600 Copier
Dark print out
check the fuser... to see if one of the rollers has toner all over it... then check your paper path... to see if you see any obvious signs... then try printing 20 pages and opening the copier at various times during the printout process... you want to see if you can catch it where the dark starts appearing... chances are where it starts... is right next to the bad part... you are looking for a print out with one half no dark and the other half real dark...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 16, 2009 | Canon NP 6035 Copier
Fault code J50 & dark strip.
This is for a Mita 1560 Photocopier (analog)
J50 was caused by exit sensor not sitting correctly in its bracket,I fixed this by pushing it until it
clicked back in.
The dark lines & double imaging can be caused light getting onto the drum ,or if the drum gets
cold (so I have been advised) which one it was for sure I will never know because when I
returned the next day & fixed the exit sensor the copy was OK.
May 18, 2009 | Office Equipment & Supplies
Poor fax printout quality
I would say you have a bad drum / toner cartridge.
Stuff you receive with vertical lines is probably the sender's dirty scanner.
Nov 04, 2008 | Canon LaserClass 2060P Plain Paper Fax
CANON 6085 PROBLEMS
No image usually in developer charge area. drum may not be going around, charge coronas (wires) broke, etc. Does it have enough toner. I have seen no image because toner was not installed. Run dark copy and see if you can see anything...
Aug 01, 2008 | Canon NP 6085 Copier
Dark Printouts
try adjusting to light is there any change? what about photo mode?
try this site for the drum
http://www.precisionroller.com/
Nov 29, 2007 | Canon ImageRUNNER 330s Copier
Canon imageRUNNER 400S Copier Logo
98 people viewed this question
old marine
old marine
