Question about Sony VPL-HS51A / VPL-HS60 Multimedia Projector
Problems using HDMI
The projector has a flickering sound as it is trying to process the HDMI signal. I am using Sony BDP S300 blu ray player. Projector was working fine with a regular DVD player with HDMI output, but recently after trying to use the blu ray, the DVD player signal is not working either. When hooking up the blu ray player, the screen says that it is not getting a signal from HDMI. Thanks.
I've had a problem with the HDMI connector, had it replaced twice while my VPL-HS60 was under warranty. This connector seems very fragile, the first time I was not getting any signal from HDMI, so the repair shop ordered a new connector and replaced it, a couple of days after the it was not working again and found that they had to solder it back on the board. If you're not getting a signal from HDMI anymore that could be your problem.
Posted on May 21, 2008
NEED TO EJECT MY DVD USING THE TIME WARNER UNIVERSAL CONTROL. WHICH BUTTON IS IT?
Universal Remote codes for Blu-ray Players - AVS Forum ' Home ...
www.avsforum.com/...control.../1297068-universal-remote-codes-blu-ra...
Dec 10, 2010 - 12 posts - ‎7 authors
Brand new Sony bdp-bx59 Blu ray player with a Rogers Atlas PVR remote, Model 1056B01 ... A button, my Samsung DVD/VCR remote's Power button in there on the ... it just means the machine you are trying to control either came out after .... I have the same Blu Ray and Time Warner remote as you do.
Eject key unavailable on sony blu ray bdp-s3200 - Fixya
www.fixya.com/.../t24026716-eject_key_unavailable_sony_blu_ray_bd...
Apr 6, 2014 - eject key unavailable on sony blu ray bdp-s3200 disk tray wont open -Sony BDP-S3200 ... Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 4 Answers .... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? ... Sony BDP-S300 tray open while updating, stuck here.
How can I fix my Sony Blu-Ray player BDP-S3200 with the ...
www.fixya.com/.../t24578583-fix_sony_blu_ray_player_bdp_s3200_eje...
Jul 27, 2010 - Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 1 Answer .... SOURCE: Sony BDP-S300 won't play any Blu Ray discs. Sounds ... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? Dec 28 ...My player cant eject disc; it say '' eject key is not available this time''.
Remote codes - Comcast Help and Support Forums
Nov 23, 2013 | Sony BDP-S300 Blu-Ray Disc Player
Can i program my cable remote for my blu ray player
Hi
I'm Sorry, you cant use an Infrared signal Remote for a blue signal Sony BDP- whatever BluRay Player.
Only a BDP-B101A - B105A gives a blue light signal for S300-S550 to get past the opening menu.
It will not sink
May 21, 2010 | Sony BDP-S300 Blu-Ray Disc Player
Just bought the sony bdp s350, bought the cable
What type of TV? Plasma / LED / LCD.. ?
Typically you should run through your HDMI ... most of the 5 RGB etc.. in the back can only be used on one of the inputs only for high def... HDMI is easier but more expensive cables..
May 12, 2010 | Sony BDP-S300 Blu-Ray Disc Player
I need to unlock blue-ray sony bdp-s360
tv repeating hdmi signal out of range did a bad choice 1080p instead of 1080i how fix the problem? thank you
Nov 20, 2009 | Sony BDP-S300 Blu-Ray Disc Player
My new BluRay player has HDMI output for both sound and video. My Receiver, however, does not have the HDMI inputs. Can I use HDMI direct to TV, and use Optical connection to receiver for audio? Sony...
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Oct 09, 2009 | Sony BDP-S300 Blu-Ray Disc Player
I have sony bdp s300 tonight it began intermittent loss of HDMI signal. It comes and goes. Not the cable, just upgraded to the most recent software. No damage to the HDMI port. This one has me beat.
What brand of tv do you have?? Also what resolution does it display? 1080i, 720p,480i or 420p?some DVD's only use certain ones. U gotta make sure your TV can display the resolution from the DVD.
Jun 28, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Bravia indicates no signal from Sony BDP S350 DVD
I once had a similar problem, although with a different TV. It was insufficient to just power down the TV -- I had to unplug the TV so that it would re-initialize. It solved my issue.
May 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
BDP-S300
I had the same problem and found a upgarde to the firmware from Sony that fixed it.
As follows:
http://esupport.sony.com/perl/swu-download.pl?upd_id=4141&SMB=YES?template_id=1&region_id=1
Good Luck!! And follow directions closely
Jan 01, 2009 | Sony BDP-S300 Blu-Ray Disc Player
BLue ray DVD player
I am not sure about the Sony BDP-S300 Blu-Ray Disc Player: But the Samsung BD-P1000 Blu-Ray Disc Player requires HDMI cable
to give the best resolution (1080p) possible that the TV set is able
to support. Hope this helps.
redthroat@hotmail.com
Nov 27, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Next Gen Blu-Ray Disc Players
My BDP-S550 HDMI has no sound coming from it, the video is fine.
May 23, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Sony VPL-HS51A / VPL-HS60 Multimedia Projector Logo
553 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
