Question about JVC RX-884V Receiver
JVC RX-884VBK RECEIVER
The LCD display quit working, along with the other components attached to the receiver, TV, speakers etc.. It does power on, but nothing else works. Any ideas?
  • 3 more comments
  • Anonymous Jan 01, 2008
    same thing here. No display. No sound. I don't know the history though, it was given to me this way.
  • bubbafrye Jan 05, 2008
    Ditto.. I tuned my Amp on an got a flashing OVERLOAD message - then the display gradually dimmed [~3-4 seconds ]. Now there is no display or audio.
    I tried disconnecting all of the speakers [2 fronts and a sub] 1 by 1 and then all of the components. Still dead after all other outputs are disconnected.
  • Mythology Jan 15, 2008
    Turns out my problem was caused by the two 125v 2amp fuses inside the unit. They are located inside(not near the power plug) under a board that may have a small square cut out to remove them. I had a local repair shop replace mine. This solved my initial problem. Currently I'm experiencing the overload problem. I've narrow this down to the three sets of speakers I have attached to a controller that connects to my amp. Either the controller is the cause of the overload or one set of the speakers is causing the overload. The amp works fine with the controller disconnected.
  • Mythology Jan 16, 2008
  • wm123242 Dec 14, 2009
    Looking for the Instruction Manual for the JVC RX 884V RECEIVER.
    Any one have the PDF file that they could send me ?
    New Friend:
I just had the same problem. Turned it on, but no display or sound. Checked the fuses on the board and at least one was definitely blown. They're 125/250v 2A 5x20mm glass tube. Easily found them on ebay for $5.28 (free shipping!), plugged them in, and all is good again.
I absolutely love this receiver!
Posted on Nov 07, 2015
    New Friend:
I had the same problem after 13 years of use. Found the fuses, replaced them and all is well again!
Posted on Nov 14, 2011
My overload problem has been resolved. I had to replaced the speaker selector(I called it a speaker controller in an earlier post). All my additional speakers were connected to this which was connected directly to my receiver. Hope this helps everyone else.
Posted on Mar 13, 2008
Wow, maybe its some kind of internal self distruct on these. Happened to me a couple days ago and sure enough my fuses were blown too. Going to hit the shack and see if it fixes it for me. Great find Myth.
Posted on Mar 12, 2008
Looking from the front. the fuses are located on the left under a green board near the top of the receiver. the green board has 2 small holes cut out only so your able to see if the fuses is bad.
Posted on Jan 17, 2008
The fuses are on the bottom side of the green board that's attached to the power supply (other side of power supply from the power cord). I'm off to radio shack now to see if a couple of fuses fixes the problem.
Posted on Jan 16, 2008
  • myk7 Jan 16, 2008
    Success! Fuses did the trick.. thanks for the tip. Now for the "time" test.
  • myk7 Nov 19, 2013
    Been working fine for over 5 years now
I checked that - good suggestion, but not the solution.
I got the flashing overload message once, and immediately shut the amp off.
Turned it back on a couple of more times and the display gradually got dimmer. I'm thinking that there must have been some kind of stored charge keeping that going for a bit longer, but whatever part of the unit that got tripped is still switched off [hopefully not for good].
There is still power to the LEDs on the front [power, unit selection and the aforementioned speaker 1/2] but no display to the main screen and no audio [except for a very distant ouput through the subwoofer]
I love this amp - sure wish I could ressurect it.
Posted on Jan 15, 2008
  • bubbafrye Jan 16, 2008
    @ Mythology:
    Could you tell us where this is located [front/back top/bottom left/right]? Thanks for the post!
The JVC RX-884VBK is a great machine, I had it for over 5 years and had no problem at all. I came across the (NO SOUND at all) and I believe it is an easy fix. Check the Front left, there are 2 keys marked 1 and 2 for SPEAKERS output, sometimes you don't notice that you connected the speakers to 1 and the 2 key is pressed. You could have both keys pressed and you will get the sound. I hope that helps.
Posted on Jan 14, 2008
SOURCE:
Can't get my center spkr.to work on my jvc rx 807v receiver
Make sure the speaker is good by connecting it to a known good working site. If speaker is good, make sure it is properly connected to center speaker terminals. Then if it is a surround receiver make sure that the sound mode is one where the middle channel works such as 5.1 DTS, etc. If the center channel still does not work then the problem lies with the decoder chip that is not working properly and sending the center channel info to that specific amplifier.
Mar 10, 2015 | JVC RX-807VTN Digital Surround System...
JVC RX-8030V, I have TV Audio hooked to back of receiver (TV Audio In) but I cannot get any sound from TV to Receiver, I can hear the speakers humm when I plug the cables in but then it goes away and no...
First of all, it is bad form and potentially dangerous to be changing cables with speaker power ON. Second, IS the unidentified TV passing audio out those jacks? Its own audio menu and controls may be between the sound and the jacks.
Oct 02, 2011 | JVC RX-8030V Receiver
How connect to tv
http://resources.jvc.com/Resources/00/00/96/LVT0380-001A.pdf this is a manual for the rx 6000 it's the same connections as my reciever pioneer hope works...............video out to TV, all components video in to receiver
Feb 20, 2011 | JVC RX-884V Receiver
Yamaha RX-V365 Receiver, Yamaha NS-AP2600S(BL) Speakers
Make sure the speaker select switch is on "A or B or AB. It's a small button on the front panel of the receiver (pen sized) and will give you visual feedback on the LCD display. If they are on, you need to have the unit bench tested at an audio shop and possibly repaired. Hope this helps
Jun 18, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Yamaha RX-770 Receiver display quit
there is a bulb inside the backlight on the lcd display.it is 12 volt and alot of manufacturers run it from the +- 15 volt preamp power supply,on the plus rail.when the bulb burns out it can activate the dc speaker protect,or some other 12 or 15 volt circuit..if it is a flourescent display that is a different problem.those run on 5 12 18 and -32 volts.there is also a 6 volt ac filament voltage.you need the schematic.
Jun 14, 2009 | Yamaha RX-770
JVC Receiver RX-6040B turns it self off after 10 seconds
the amplifier is seeing a short,or the internal components like one of the output ic are causing dc to show at the speaker terminals.the speaker protect is causing it to shut down.
May 14, 2009 | JVC RX-6040 Receiver
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
Speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Jan 02, 2009 | JVC RX-554V Receiver
RX-668V - Center Speaker Channel
have a tech check your set it is a bad cap that that bias a very small voltage to that circuit or it could be cold solder.good luck.
Apr 15, 2007 | JVC RX-668V Receiver
JVC RX-884V Receiver Logo
1,999 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
