Question about Microsoft Excel for PC
Micosoft Excel How to go from one worksheet to another worksheet in excel
  • jois Dec 03, 2007
    My exact quiry is "How to go from one worksheet to another worksheet in excel without using mouse". For which I need answer pl
Ctlr and tab
Posted on Dec 04, 2007
    Sergeant:
    Champion:
  • 298 Answers
33
34
35
36
ii I i]\sheet1 sheet2
click ^ or ^
Bottom left corner of workshet
Posted on Nov 29, 2007
  • Eugene Merritt Dec 03, 2007
    Sorry about that its
    ctl pgdn/pgup
    press and hold control and click page
    up or page down to toggle worksheets
  • Eugene Merritt Dec 12, 2007
    Was this solution helpful? Show your Appreciation by rating it:
    Comment by tech8, posted on Dec 03, 2007 Sorry about that its
    ctl pgdn/pgup
SOURCE:
My excel is starting right to left in window 7
The default worksheet direction in Excel 2007 or 2010 is Left-to-Right. To change a worksheet direction to Right-to-Left, follow these steps:
  1. In Excel Ribbon click on the Page Layout tab.
  2. In the Sheet Options group click Sheet Right-to-Left. The sheet direction will be changed. Column A will now be to the far right. Columns B, C, D.. etc. will follow to the left.
- See more at: http://www.exceldigest.com/myblog/2012/04/29/how-to-change-worksheet-direction-in-excel-2010-to-right-to-left/#sthash.lSG25YXq.dpuf
May 27, 2014 | Microsoft Excel 2010
What is a workbook?
A workbook is a spreadsheet file. By default, each workbook in Excel contains three pages or worksheet
The term spreadsheet is often used to refer to a workbook, when in actual fact, spreadsheet refers to the computer program, such as Excel.
So, strictly speaking, when you open the Excel spreadsheet program it loads an empty workbook file consisting of three blank worksheets for you to use.
Jun 25, 2011 | Microsoft Office Excel 2007 Full Version...
What is default name in ms excel? how is possible excel worksheet in excel?
Book1.xls Do you mean that you can't find the worksheet you have establish and you haven't rename the file? The worksheet will be OK if it had been saved.
Feb 15, 2011 | Microsoft Office 2010
Describe the each part of microsoft excel 2207
Parts of the Excel 2007 Screen
Active Cell In an Excel 2007 worksheet, the cell with the black outline. Data is always entered into the active cell.
Column Letter Columns run vertically on a worksheet and each one is identified by a letter in the column header.
Formula Bar Located above the worksheet, this area displays the contents of the active cell. It can also be used for entering or editing data and formulas.
Name Box Located next to the formula bar, the Name Box displays the cell reference or the name of the active cell.
Row Number Rows run horizontally in an Excel 2007 worksheet and are identified by a number in therow header.
Sheet Tab Switching between worksheets in an Excel 2007 file is done by clicking on the sheet tab at the bottom of the screen.
Quick Access Toolbar This customizable toolbar allows you to add frequently used commands. Click on the down arrow at the end of the toolbar to display the toolbar's options.
Office Button Clicking on the Office Button displays a drop down menu containing a number of options, such as open, save, and print. The options in the Office Button menu are very similar to those found under the File menu in previous versions of Excel.
Ribbon The Ribbon is the strip of buttons and icons located above the work area in Excel 2007. The Ribbon replaces the menus and toolbars found in earlier versions of Excel.
Here are the main parts of Microsoft Excel 2007. Thank you for using Fixya !!!
Nov 15, 2010 | Microsoft Windows XP Professional
How do i open an excel 97-2003 worksheet file?(Microsoft office.)I have windows xp
Go to start go on microsoft office then go to micosoft excel and it should come up.
Nov 11, 2009 | Microsoft Office Professional 2007 Full...
Import data from access into excel where one column go into one worksheet and other into next
Can't be done.
Access will only put the data into one worksheet. It is very picky when it comes to exporting data into an Excel spreadsheet.
There are two ways to get around it:
1) You can export the data from Access into two files. One for the the first worksheet and another file for the second workshet.
2) You can import everything into one spreadsheet and build a macro into Excel to cut the information one spreadsheet and paste it into the other if this is a redundant task to do all the time.
Hope that helps you out.
Jun 10, 2008 | Microsoft Office Access 2003 (077-02871)...
MS EXCEL 2000 corrupted workbooks/worksheets
it sounds like you are going over the limits of the program these are the specs. I would recommend dividing up the data if you can. or moving it to a database that can act like excel and hold more data.
Apr 29, 2008 | Microsoft Excel for PC
Forgot password to open Excel sheet
If you mean that you can open the Workbook and read the Worksheet - then all you have to do is select all and paste it to another Worksheet. This will allow for changes of formulas etc.
If you mean the whole Workbook - then I dunno.
In future, either use the same password for everything (easy to remember) or Protect the work with nothing entered into the password field (leave this blank). This last will protect the work from people who try to guess your password, but will be easy for you to remember - eg every password is left blank.
If you must use unique passwords, then keep a record of them somewhere other than on your computer.
Sorry I can't help with the "Workbook" solution - but somebody else out ther may be able to do so.
Apr 25, 2008 | Microsoft Office Professional 2007 Full...
PASSWORD RECOVERY
Try to Recover Excel Password with Excel Password Recovery 5.0. I have searched MS Excel Password Recovery, found this efficient Excel Password Recovery program. It supports all versions through 97 to 2007.
Remark:
Office Password Recovery tool also can help! It recovers Password to Open and removes both the Password to Open and Password to Modify for Microsoft Word, Excel, Access and PowerPoint of versions through 97 to 2007.
Feb 18, 2008 | PC Chips M825G Motherboard
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
