Question about ASUS A8V-VM Motherboard
ASUS K8N-VM Motherboard.. audio not working..
Help me guys..
i am using a asus k8n-vm motherboard based on geforce 61_x0 series and a semron 3000+ processor.. and os is windows xp professional sp2..
my audio device is not working.. i just cannot find out whats wrong.. in device manager it shows legacy audio driver installed and the properties says its working properly.. but when i try to play an audio file it shows `bad sound driver`
i have tried all the usual stuff..reinstalled it , searched the internet for the driver .. but its of no use.. ihave downloaded the k8n-vm drivers package from two different locations but both the times it shows a long list of errors while unzipping.. once i downloaded an audio driver.. on unzipping i got asingle file named 403.ROM.. plese someone tell me what to do with that file..
thanks in advance..
appus
I am having asus a8v-vm mother board and amd 3000+ processor.. and os is windows xp professional
i have tried all the usual stuff..reinstalled it , searched the internet for the driver .. but its of no use.. please guide what to do
Posted on Dec 06, 2007
    Problem Solver:
  • 15 Answers
Ok i have encounterd such a problem myself , it works on some systems but just give it a try , download the "soundmax digital intigrated audio" pack , it comes with audio drivers and all neccesary software
Posted on Nov 29, 2007
SOURCE:
Hello, I have a problem with my mobo asus K8N-VM. Not send signal to the monitor. Please give me some advice!
make sure battery is in mother board make sure the fuse is good and in mother board make sure aluminium tower is clamed on black chip to mother board and also make sure fan is cecurelt tight on mother board.
Feb 26, 2011 | ASUS K8N-VM Motherboard
K8n-vm asus motherboard supporting processors?
Here are the compatible processor for this motherboard AMD Athlon 64, AMD Sempron that you can choose from.
Dec 07, 2010 | ASUS K8N-VM Motherboard
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
How to downlode driver asus mother board k8n-vm ?
Hi, try this link for your drivers:
http://www.driverstock.com/ASUS-K8N-VM-driver-download/6-9-10112/index.html
Aug 13, 2010 | ASUS K8N-VM Motherboard
The south chipset bridge of my Asus k8n-vm motherbard heats up
85 to 95 is ok. Anything higher than100 is pushing it. If possible add a fan to the side of the system case (Best choice) or you can buy a south bridge fan. You're MB doesn't have holes in the MB to attach a chipset fan but you can still attach a cooler on to the chipset. Like this fan; http://www.newegg.com/Product/Product.aspx?Item=N82E16835103155
And you'll need this as well for a good bond; http://www.outletpc.com/c2019.html
Enjoy!
Mike
Jun 12, 2010 | ASUS K8N-VM Motherboard
I need to restore factory settings how do I ?Actually it is on pc period I need to reset it to factory settings, but that k8n-vm is as it states the motherboard I am using? Please:)
Easiest fix for this is to simply remove the CMOS battery, but there also should be a configurable jumper on the board, in the same area as the battery, that can be set so as to return the board to Factory settings.
Apr 16, 2010 | ASUS K8N-VM Motherboard
Motherboard live then 1 beep followed by 4 beeps then nothing.
The one beep is usually normal for most computers. Is your Video card seated correctly?
4 beeps Refresh error RAM is not refreshing correctly. Reset the refresh values in the BIOS or reset the BIOS.
Jan 14, 2009 | ASUS K8N-VM Motherboard
ASUS K8N-VM mother board win98 drives
Try going to the Asus website and look for support for your MB drivers and Operating System.
If there is no longer any Win98 support for your MB then I suggest a fresh computer and more recent software for less hassle!
A ten year old OS indicates to me that you might be stuck until you go with the flow!
Cruel but true.
Hopefully the recent cheap prices for computers pre-installed with Vista or XP will persuade you.
Feb 06, 2008 | ASUS K8N-VM Motherboard
ASUS A8V-VM Motherboard Logo
558 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
