Question about Sony Cyber-shot DSC-W35 Digital Camera
Help with red flash?????
Everytime i take a picture there is a red flash and there is also the white flash, how do i remove the red flash?
thank you
Racine
Do you mean, the AF Illuminator (the bright orange/red light that appears before the picture is taken)?? If so, all have to do is click on menu, scroll all the way to the right (into the setup menu) and go to the camera icon. From there, go down to the AF Illuminator and switch it from "Auto" to "Off".
Hope that resolves your problem!!
Posted on May 14, 2008
SOURCE:
Flash Drive (Kingmax) cannot be read by the computer
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no
dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with post a reply
hope it helps
Jul 06, 2012 | Electronics - Others
Everytime I snap a picture, the camera flashes three times. Help!
The camera is in Red-eye Reduction mode. The preflashes are intended to get the subject's pupils to contract, reducing the red-eye look.
Press MENU to display the menu. Press right-arrow to select the toolbox icon (Setup). Press the arrow keys to select Red Eye Reduction, and turn it off.
May 14, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
Red eye on sanyo digital camera xacti,always theres a red eye when taking pictures,i already adjusted everything,still occuring red eye.
Do you mean your subject's eyes are showing "redeye"? This is a common problem with cameras that have the flash very close to the lens. Almost every photo editing program has a tool to remove red-eye. Check your computer to see what you have installed. In the future, most cameras have a red-eye flash setting which shoots a short flash before the main flash to close down the pupils in your subjects eyes to eliminate red-eye. You could also turn up the lights in the room...sometimes that helps.
Apr 28, 2010 | Sanyo Xacti VPC-T700 Digital Camera
PICTURE LAG WITH HDMI HOOKEP TO RCA 42'' L42FHD37
Check in your TV's settings for a selection called "Game mode" It will turn off the scaling chip in the TV(The PS3 will scale the image anyway) and remove the lag it was producing.
Jan 03, 2009 | Sony Playstation 3 (PS3) Console
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
Blank and blinking
the firmware need to be reflash on the phone so take the phone toa mobile service center and have them flash it for you or you can do this online at topsony.com.
Oct 31, 2007 | Sony Ericsson K610i Cellular Phone
Flash causing a white out!
you are possibly using it too close to subject. Make a softening/dimming filter with layer of tissue paper over the flash- the more tissue the less light gets out
May 23, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
Animal Eyes
I've seen some of those white eyes photos. Some are down right scary. I'm sure you have encountered red-eye when taking flash photos of people. With some animals, it is not red - but white. .... Try to catch the animal looking away from the camera when you take that flash picture. Have someone distract him/her. ............ Fixing Demonic Pet Eyes http://graphicssoft.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=graphicssoft&zu=http%3A%2F%2Fwww.myjanee.com%2Ftuts%2Fpeteyes%2Fpeteyes.htm http://graphicssoft.about.com/gi/dynamic/offsite.htm?zi=1/XJ&sdn=graphicssoft&zu=http%3A%2F%2Ftlbtlb.com%2Ftlbimages%2Fmax2.html
Aug 31, 2005 | Canon PowerShot SD400 / IXUS 50 Digital...
Sony Cyber-shot  DSC-W35 Digital Camera Logo
116 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
