Simmons Outdoor AETEC 2.8-10x 44mm WA (2.8-10x44 mm) Logo
Posted on Nov 29, 2007
Illuminated reticle won't work
I have 2 like new Aetec 2.8x10 the lights won't work, have tried changing batteries and caps with working Aetecs with no change. Simmons has no customer service that I can reach. Any numbers or ideas would be helpful.
1 800 285 0689 puts you on forever hold.
A
Anonymous
CANNOT ADJUST MAGNIFIER
1helpful
Why are gun scope/sight reticles normally red in color?
The illuminated reticles of optics are generally red and green to allow for better contrast against various dark backgrounds while also not sending a piercing light into the eyes of the shooter. Red and green are also typically not as noticeable from the barrel side of the gun as a color such as white would be.
Jun 03, 2018 • Optics
Replace batt on NcStar Scope 3-9x42E
The battery on lighted reticle scopes is located underneath a screw off cap on the rheostat switch usually on the ocular lens housing. Hold the base of the switch with one hand and unscrew the cap with a coin. Replace the battery with a CR2032 button type battery (this is the most common battery size for these)
Hope this helps, Mark the Gunsmith
Please leave feedback.
Jan 13, 2010 • Optics
Simmons aetec, put on muzzleloader to boresight and adjustments work in reverse.
It's a common misconception to think that you're moving the bullet impact on target, when in fact you're moving the scope's reticle to look where the rifle is shooting.... So if your shooting left of your target.. you want to move the crosshairs to the right.
Hope this helps, mark the Gunsmith
Please leave feedback, Thanks!
Jan 09, 2010 • Optics
3helpful
How do yoyu change the battery on the reticle
Most models, the battery is located within the knob switch that illuminates the reticle, and can be accessed by removing the screw cap/insert of that knob.
Good luck
How long can epsonR1900 printer last ?
RETURN PRINTER FOR FACTORY REPLACEMENT OT TO THE POINT OF PURCHASE.RICHARDM69
Top Simmons Outdoor Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Simmons Outdoor Optic Expert? Answer questions, earn points and help others
