You'll have to remove the top and remove the disk that way. there's a top bracket on the dvd drive to remove before you can get to the disk. and unplug the unit first!!
This may sound obvious but, try pressing the open button when the unit is powered off.
The tray should open as it powers on not giving it a chance to turn the disc and start reading.
I have the same problem with certain discs, normally what I have burnt myself.
Post back if no good.
Ur dvd motor not good it going bad.Not worth repairing because DVD players so cheap this days.But if u want ur DVD disk back u must open the cabanet with a screwdriver get ur DVD disk back.
Please check the bellow instructions:-
Turn off your DVD player. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
Please get back to us if you have any further query or else accept the solution.
Reading the manual I found the solution. I just had to make a restart (pressing power on while connecting the cable). The problem is solved.
Thanks any way!
Best regards!
