Question about Mustek A3 USB Flatbed Scanner
Installation problems Am having problems with Mustek P3600 A3 Pro Scanner drivers - they appear to not to load properly although device manager on Win XP SP2 PC says no fault with the hardware. The "panel" comes up on screen but hangs during scan. Have tried complete uninstall and reinstalling - same issue reappears.
  • 4 Answers
Did you plug the scanner in before installing the software? Common mistake... Disconnect the scanner, uninstall the software completely, re-boot, open up the Device Manager, Click View-->Show Hidden devices--> Look for any scanner related drivers that are still installed for the scanner (they will moste likely be grayed out since it is unplugged) and uninstall them (Right click-->Uninstall). Re-boot again, install the software, wait for the software install to prompt you to plug in the device. Follow the quick start guide if it came with one. Check the manufacturers web site for updated drivers, software for you model.
Posted on Nov 29, 2007
SOURCE:
The cable works but the machine doesn't start.
A scanner has to warm up, if the bulb does not come on to warm up, it wont start. Check the bulb first.
Aug 26, 2013 | Mustek P3600 A3 Pro Flatbed Scanner
I need to download a Mustek SE A3 USB 600 PRO Driver for Windows 7 for the device which got lost.
Hi anderoland
There is no support at Mustek's for Windows 7 . You can't use your device under this OS .
best regards ,
fanaudi .
Sep 02, 2011 | Mustek A3 USB Flatbed Scanner
Driver for Mustek P3600 A3 pro for Widows 7
ftp://ftp.mustek.com.tw/pub/driver/PA3pro/Win7/ much better link for when the sites down like it is for me now. :)
Jun 17, 2011 | Mustek P3600 A3 Pro Flatbed Scanner
I cant get my new macbook pro to recognize my mustek Scan Express A3 USB 1200 pro, and i haven't been able to find a driver to fix it so far.
Here is the page to download the drivers you need for the Mustek ScanExpress A3 USB 1200 Pro Scanner:
http://www.mustek.com/mustek/supportdrivers.php
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Mustek ScanExpress A3 USB 1200 Pro Scanner
Mustek A3 Mac OS X driver?
http://www.mustek.com.tw/apprg/countdriverdownloadtimes?LINK=ftp://ftp.mustek.com.tw/pub/driver/A3IIIU2/2400DPI/MAC/10.4-10.6/SE%20A3%20USB%202400%20Pro.zip&DRIVERFILEID=305
it said there is teh driver for mac 10.4-10.6
is from the support sidte of the manufacturer..in the category of office use..and it is the eexact model..but it is just the driver ..the software was not available ..there ..but I guess you can use a photo manager to import from device..
May 10, 2010 | Mustek A3 USB Flatbed Scanner
User Guide for Mustek A3 USB 1200Pro Scanner for an Applemac ?
So, click on this link:
Fill in the fields, Scanner / USB / Model # and you will have access to the newest drivers and the manuals and everything...
Oct 24, 2008 | Mustek A3 USB Flatbed Scanner
Mustek a3 usb 1200 pro scanner problem
I bought one a couple of years ago. After plenty of hit-miss after trying to get it to work on my fresh XP installations, I have a solution. Installing it the normal way simply doesn't work.
First, go to 'start', 'control panel' then 'system'. Click the 'hardware tab' then press 'device manager'. You'll see a list of hardware.
If your scanner is already plugged in, find it (it could be listed under 'imaging' or under 'other devices'. You should see a yellow exclamation point indicating it's there but not working.
If you go to 'control panel... system' first, and then plug in your scanner, it will pop up automatically.
Now, right click on it, select 'update driver'. A window pops up. Insert the CD, then select 'have disk' and install normally.
Installing the remaining software is optional (acrobat 4.05 and so on)
I've used the "Panel" to scan my pics. Working like a charm.
Feb 07, 2008 | Mustek A3 USB Flatbed Scanner
Mustek 1200 UB Flat bed scanner
SELAM BENDE MUSTEK 1200 UB VAR XP NASIL çALIŞTIRA BİLİRİM XP DOSYAYI YüKLEDİM AMA çALIŞMIYOR 98 çALIŞIYOR YARDİMCI OLURSANIZ SEVİNİRİM TŞKLER [email protected] teşekkürler
Mustek A3 USB Flatbed Scanner Logo
581 people viewed this question
Top Mustek Office Equipment & Supplies Experts
Mike
gggg
Are you a Mustek Office Equipment and Supply Expert? Answer questions, earn points and help others
