When i plug my g1 into the computer it shows all the music i have and thats fine! but wen i un plug it and look at the music on my phone its showing way less songs then wat it previously showed on the computer.. i dnt have all the music showing on the g1!
Call up tmobile, do not tell them you have a rooted phone or that it was modified in anyway, otherwise they will blame it. They will be able to help you get it working by modifying / adding some settings in your phone.
Put it in your PC and format it such that it allows for more items - music - to be added to or removed from the memory card whenever you waht to do that. That way, it will allow you to add and remove music whenever you want to do that, and it will not lock down the memory card. I have done the same thing with my 32 GB Flash Drive, and it works like a charm.
Umm..... did u try formating the card? before you do that backk all info on computer via usb cable. if the G1 says mount to usb go ahead and mount it. in your case it might not work. but try it anyway. if no good goto settings on the G1 then goto SD and internal memory and tap eject SD card then pull it out then push it back into the slot tell me if it works on the PC now.
I had the same problem. so what i did is i created a back up on my computer and format it the sd card. and it had a bad file in it that was causing the problem. once i format it the card it was ready to be used again. just make sure you look for that corrupt file so you don't put it again to the already clean card. also i removed the sd card from the g1 and plugged it straigt to the computer. I hope this can help you like it helped me.
Hi.. If the files were loaded to the SD card directlt from your computer via a card reader, try deleting them while in Safe Mode.If loaded directly to your phone, check if there is a setting on the phone or on the file properties to protect the files. If so, adjust it as needed, then attempt to delete the files again.
I have a Windows Vista Computer and this is how it worked for me.......
This is fairly easy. Plug your G1 into a computer thru the USB cable provided. Shortly a window will appear on your screen showing a mobile device storage unit has been attached. That window is the G1's memory card. You should OPEN the file called music then open a new explorer window to your music directory. Simply Drag and Drop from your music directory to the G1's music window.
Step 1: Plug in your USB cable to your G1 T-mobile phone as well as the computer. Step 2: On your G1 T-mobile phone you will see a small icon at the top of the screen that symbols the USB. Step 3: Pull down the notification window down and click on USB Connection. Step 4: Automatically on your laptop computer or just computer a window will pop up giving you the option of importing pictures and copying them or just viewing them.
These steps are the correct steps.....T-mobile G1 technical support has not yet modify these steps or include them on the T-mobile G1 manual.
when you plug the phone into your pc using the USB cable an alert appears at the top of your phone notifying you of the USB connection. Slide the alert open and click on the "USB connected Select to copy files to/from your computer" alert. It gives you the option to mount the drive. Click on "Mount" - once you mount the drive. Open your file browser on your PC and the phone should be mounted as a flash drive. Click on the drive, you should be able to see all of the folders on your SD card including the folder containing your music.
