Question about GE Profile JTP18 Electric Single Oven
Digital screen goes off oven will not work stove top is working fine
When the digital screen goes off, the oven stops working, stove top works fine sometime the digital jus tcomes back on, open the door and close it and poof its off again I am screaming I cant trust my oven to cook on right now its only 8-9 years old. digital will flicker sometimes too.
  • rickhines Jun 24, 2008
    on the power leads on the oven there is a voltage drop on one leg to 90 volts and a increase on the other lead to 150 but with the board unhooked there is 120 on each lead
  • Anonymous Mar 22, 2014
    oven is not working (stove is). On digital display screen there are three orange lines and I cannot erase it or do any function
The "digital screen" is connected to the electronic control board which controls the oven (the surface elements on the stove top will not be affected by this problem). The "flickering on and off" could be any connection that feeds the electrical supply of the control board. Like something in the wiring harness that feeds the relay board, or the wiring harness that goes from the relay board to the electronic control board. It could also be the relay board or the electronic control board themselves. To isolate the problem you would need to check electrical supply to each board at the time of the "problem" when the "digital screen goes completely off." This would tell you where you "have" the voltage and where the voltage supply is lost. If it is a loose or burned wiring harness replace the harness or individual wire causing the problem if it turns out that it is the relay control board or electronic control board replace them. The relay control boards are typically around $75.00 and the electronic control board $150.00 and up. Might be cheaper to purchase another used oven or bite the bullet and buy a new range.
Posted on Nov 30, 2007
My oven doesn't turn on but the stove top works fine. It just blinks e0 03
I would check the heating element assuming this is an electric.
Jan 28, 2013 | Ovens
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
The stove top works fine .Both of the ovens stopped working and there is no digital display where the clock is . Where is the fuse located for the ovens
Normally, there is a master switch on the wall near the oven. This is in turn is usually fed from its own fuse/breaker on the consumer unit. I suspect this has bblown.
Jul 18, 2011 | Stoves 720EF Electric Double Oven
Kitchenaid superba electric oven (includes convection feature) and the entire digital panel suddenly stopped working after 6 years of perfect service. The stove top burners (acrylic top) appear to be...
It sounds as if the electronic clock/timer has failed and needs replacing. If you don't use the timer and don't need the clock it can be bypassed so that the oven will still work. A repair person should be able to do this fairly easily.
Feb 13, 2011 | KitchenAid Ovens
Hello, We have a Kenmore gas stove model # 71761. The burners on top work good.The issue is with the oven portion. Oven is working. Flame comes on upon ignition to desired temperature setting and then...
It sounds like yous stove is working fine. Cycles fine. If you think the stove is cycling more often than when new then ck the seal on the door. You may be loosing heat.
Jan 14, 2011 | Ovens
Stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Jan 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
May 22, 2008 | Ovens
GE Profile JTP18 Electric Single Oven Logo
265 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
