Question about Xerox Phaser 7700 Laser Printer
Phaser 7300N I have a phaser 7300N. Recently whenever I print a document I get a color print of the menu map. how can I stop this and what the reason. Thks Zoher
    Novelist:
  • 208 Answers
I would say this will have to be done to stop that.
But you will have to basically set up the printer as if you were newly installing it.
Resetting the NVRAM will reset all printer values including network, printer setup, job defaults, and color calibrations.
  1. Press the Down arrow key and scroll to Support.
  2. Press the OK key.
  3. Press the Down arrow key and scroll to Service Tools Menu.
  4. Press the OK key.
  5. Reset NVRAM will be displayed.
  6. Press the OK key.
  7. Reset NVRAM and Reset Printer NOW will be displayed.
  8. Press the OK key to reset all the settings to default.
Posted on Dec 05, 2007
SOURCE:
Is it possible that a print driver may have caused my printer to stop printing black
Try printing an internal print page like the configuration page. If the page is printed in black and white then there is a problem with the printer. If the page is printed in colour then the printer is fine and the problem is with the driver or the driver adjustments.The driver itself can not cause a permanent problem to the printer.
Sep 19, 2014 | Xerox Phaser 7300N Laser Printer
Can't get black to print
It can tell you it has lots of toner, but I would check the cartridge to be sure. Also the waist toner bucket, because as soon as it is full, it will inhibit printing too.
Xerox Phaser 7300n black text does not print
Unplug power, wait and repower. Try an older cartridge.
Xerox Phaser 6125 prints pink
you cal also try to clean the laserwindow of the Magenta imaging unit
Nov 08, 2012 | Xerox Phaser 6125 Laser Printer
PCL5 OUT OF MEMORY Phaser 8860
After reading some similar stories, I simply restarted the Xerox Phaser printer via the menu on the physical printer. I theorize perhaps the Phasers on board memory could have been bogged down from all the pictures involved in the problem documents and all the size problems associated with large files.
thorntravis
Oct 07, 2009 | Xerox Phaser 8860MFP/D - Multifunction -...
Phaser 7300n Printing on Double Sided Glossy Paper
At first I didn't think the paper was the problem, but I looked up the specs on it and is seems to be a paper designed for an offset press.
I suspect after reading the information on the paper that the coating is not designed for the high temperatures of a laser printiers fuser heat of over 350 degrees.
I do suspect the paper is the issue.
sounds like you are melting the coating.
Dec 30, 2007 | Xerox Phaser 7300DN Laser Printer
Xerox phaser 8400
The first obvious question is, "Does it have blue ink/wax?" Is it displaying any errors? Have you tried the Xerox support site? They have a fantastic utility that can connect to your printer and diagnose many problems. Here's the URL for the utility: http://www.phasersmart.com/ They also have a wealth of information in their knowledge base. Here's the URL for the support page for the Phaser 8400: http://www.office.xerox.com/printers/color-printers/phaser-8400/sprt-enus.html Did anything happen before the blue quit printing? Have you tried running a cleaning cycle?
Aug 21, 2007 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 7700 Laser Printer Logo
156 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
