Question about Onkyo HT-SR800 System
VOLUME CONTROL After set up, no sound is heard until volume control is at 25 or above.At Minimum through 25 no sound is heard from the speakers.Faulty receiver?
  • Anonymous Dec 01, 2007
    volume
    volume control
Try to increase the speaker levels through setup. I had the same problem and I increased the speaker level from 0dB to +10dB, and seems like it is better now. Let me know how you make out.
Posted on Dec 04, 2007
SOURCE:
No beep sound and no display
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the selected correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line or use a can of compressed air specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if its a desktop swap the speakers around if one still does not work its either a faulty speaker or the speaker connection
hope this helps
Sep 13, 2012 | Intel DG31PR Motherboard
Sound card working properly but no can be heard
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
Oct 16, 2011 | Dell Computers & Internet
Cannot hear sound
they might be muted or have faulty connections/leads
also
Sep 28, 2011 | Compaq Audio Players & Recorders
Speakers are plugged in and power can be heard through them but no audio sound is coming through. I have just had a system repair on my PC (in case this helps in answering)?
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 22, 2011 | Kinyo PA-390 Computer Speakers
No sound but good pic, checked mute, set up, etc..
There is a possibility that your speaker is defective, check the unit by using earphone . if still nothing is heard.adjust volume control minimum to maximum.still nothing.. audio amplifier is the next thing to blame. you may replace it. or call a serviceman to do that.
Feb 25, 2011 | Apex Digital PF3230 32" TV
Sound comes out of the right speaker with the z4 volume set at minimum. however the sound can be controlled by the windows volume control. When you turn up the volume on the z4 the left speaker works....
open your subwoofer because main system is inside in your subwoofer than clean it with a air blower ..
this happens when dust is inside the system....
Dec 26, 2010 | Logitech Z4 Speakers
How do i get the sound back on my laptop please help me
Is the speaker on "MUTE" or volume to minimum it is also possible that WAVE is at minimum. Go to the bottom right on the desktop and find picture of a speaker, right click on in and chose open volume control and check if there are any MUTE or volume at minimum
Nov 14, 2010 | Computers & Internet
The volume on the tv wont work and i have disassembled the back to look at the wiring but do not know where the volume wires are located. do you think you would provide me with some assistance?
Hi
The volume control on all digtial tvs are control by the main cpu electronicly , not by a pot as in older tvs. If you have no sound cheek if there is a speaker sw on the main menu if not does the set have a head phone connection , can sound be heard from this with a set of head phones, if so the speaker is faulty or the head phone socket might be dirty regards windyhouse
Sep 08, 2010 | Dynex DX-L15-10A 15 in. HD-Ready LCD TV
No Sound
1) First check the mute.
2) Make sure there aren’t headphones plugged in, that will disable the speakers.
3) Check the audio setup
4) Check your Volume lock
Changing Volume Lock
The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock).
However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will
control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to
set its volume control for independent operation or Global Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
1. Press and hold SET until the red LED blinks twice; then release.
2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV).
The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example,
TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now
independently controlled for all programmed devices.
Unlocking a Single Device’s Volume Control
1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected
Mar 15, 2008 | Polaroid FLM-2632 Television
Onkyo HT-SR800 System Logo
136 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
