Question about Sony Cyber-Shot DSC-T3 Digital Camera
Not able to take picture
When i switch on the camera, it has suddenly started showing thin stariaght lines on the full screen. Nothing is visible on the screen.
Please advise me.
  • minksh4u Dec 02, 2007
    well tried
  • Aakriti Feb 14, 2008
    my cam is showing the same problem and that too over night! thin red lines all over. how long will it take to repair it?
    Sergeant:
    Champion:
  • 231 Answers
If lines are visible only when using in camera mode.The camera might have a CCD imager going bad or lens ribbon , connector problem .If lines are NOT visible when using playback mode.Then problem should be in lens area(CCD)..
Posted on Nov 29, 2007
SOURCE:
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 | Cameras
After taking pictures on a full screen, suddenly my camera appears to be set showing a black frame below/above for horizontal, left/right for vertical. I can no longer return to the full screen... wh
You've apparently switched your camera to the widescreen mode. To switch to another mode, follow the instructions under "Changing the Recording Pixels (Image Size)" on page 65 of this manual.
Mar 23, 2013 | Canon PowerShot SD1200 IS / Digital IXUS...
I have thin white lines that run across the top of my picture. They are only visible when picture is full screen. The wide screen picture (with the black areas at the top and bottom) do not show this. The...
sounds like bad capacitor in vertical circuit. It's not a hard fix if you know where to look. Repair shop should not have hard time repairing it.
Aug 10, 2009 | Televison & Video
Sony T3 cybershot screen black
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=7&NAVDISP=di
Mar 11, 2009 | Sony Cyber-Shot DSC-T3 Digital Camera
Camera does not react
I quote: "A couple of days ago after using it when trying to see the pictures on the camera the LCD did not show anything. The lens reacted and even take pictures but nothing was visible on the LCD screen."
That means that there was a problem either with a LCD display or with ribbon cable.
Now:"I tried charging the battery and removing it from the camera, now the camera only does a bit sound when switching on but nothing else, the lens does not even come out."
That means that the ribbon cable had probably shorted, now the camera may be furtherly damaged.
The camera must be disassembled to access the LCD and fix the problem.
The repair must be done by an experienced technician, as to access the LCD you need to remove both covers.
Jan 07, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
File Error
i have the same problem too! ughh it so annyoing.
Feb 27, 2008 | Sony DSC-T70 Digital Camera
Blank Screen
Yes they'll fix this for free, see:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
Note that Canon should fix this for you free Worldwide. Sorry, but I don't understand French. But here's a starting point for your search for repair help in France:
http://www.canon.fr/Support/index.asp
Dec 28, 2007 | Canon PowerShot A75 Digital Camera
File Error
I also have the same problem
Dec 17, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony Cyber-Shot DSC-T3 Digital Camera Logo
60 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
