My drum will not spin
I HAVE A HOTPOINT AQUARIOUS PLUS 1200 AND THE DRUM WILL NOT SPIN. IT FLASHES E30 AND WHEN I LOOK IN THE GUIDE IT SAYS CONTACT ENGINEER. I HAVE CHANGED THE BRUSHES BUT IT STILL WONT WORK
    President:
  • 1,294 Answers
Plug off the wall first. The spin normally does not work when the outlet filter is clogged; locate & clean out, be prepared for a flood of water. If the filter is clean you should then check your pipe coming out from under the tub. Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
You can also drain water from the tub thru the rear hose in the wall. Keep bucket handy. The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground. Do not push the pipe too much down the stand pipe.
Posted on Nov 30, 2007
  • prem mathew Nov 30, 2007
    And dont forget to rate me pl.
SOURCE:
When on spin mode the machine makes a terrible grinding noise and won't spin on 1200 speed Hotpoint Ultima WT965 7kg
Turn drum by hand, if you feel it catching, its something between the drum and tub, put in through soap draw usually by children. Can be removed by taking out the heater element to get access under drum.
If it feels rough all the way round when turned and it can be lifted up slightly ( free play ) then its probably the drum bearings and seal failed.
Oct 20, 2013 | Washing Machines
Why does my my frigidaire front loader washer reads diagnostic code e30
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
Dec 19, 2012 | Hotpoint Ultima WF860 Front Load Washer
Our Hotpoint WF321 1200 spin is just 3 years old and now makes a very loud noise when in use - both for the washing and spin cycles. is the drum loose / off balance? any help appareciated
Remove lower rear cover of washer, remove drive belt, and from the front spin drum by hand, if it feels rough, or is rumbling, or noisy, then the main drum bearings are failing.
This is a major repair!!!.
Mar 13, 2010 | Hotpoint Washing Machines
Loud noise when spin drying, rumbling sound, sounds like concorde taking off! Hotpoint Aquarius 1200 washer dryer WD62
Remove rear panel of washer, and remove drive belt.
Spin the drum by hand, and if it feels rough, or is noisy, then the main drum bearings have failed, quite a big job to do.
Please rate my solution.
Thanks.
Nov 07, 2009 | Washing Machines
Hotpoint Aquarious 1200 IE When spinning the drum ocsillates violently and is very noisy.
Remove drive belt, and spin drum by hand, if noisy or rough, then bearings have failed, if no noise, then could be suspensioon leg problem.
Tghanks.
Sep 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarious 1000 de luxe
You need to check the lateral movement of the drum if it moves by more than 1-2 mm then the bearings need to be replaced.
Apr 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Brushes
if replacing the brushes has not fixed then its most likely the motor is duff.
Feb 18, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
171 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
