Question about Motorola Mobility RAZR V3i Cellular Phone
Connectivity I dial a number. It says I am connected (I dailed home and got my answering machine). But I cannot hear anything or transmit any sound.
  • jackeduprazr Feb 02, 2008
    I have the same problem. My phone connects to the number that I
    am dialing, however I cannot hear anything on the phone unless I put it
    on Speakerphone or connect via the Bluetooth in my car. Does
    anyone have a solution?
  • PhotoJames Feb 20, 2008
    The problem I had was because my bluetooth earpiece was on but did not know it.
  • 72 Answers
Sounds like a carrier issue or a hardware issue. if both you guys have the same problem. could be a lemon defect.
Posted on Feb 16, 2008
SOURCE:
Fax will not connect. it dails and you hear it connecting but will not transmit
It could be a few things. It sounds weird but try a different Fax number. It may be the number your calling. To test it look up someones fax number online (say cannon) under the contact us and dial that number and see what happens.
Jun 24, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I place my paper that I want to fax in the fax machine,dial the number that I want to fax, push start, it scans the paper, I hear the fax tone and at the end I get a Beep Beep Beep and the report sending...
1) did you dial correctly?
2) are you in an office or in your own home?
a) if you are in an office, you may have to dial a 9 or someother number to dial out before you can type in your original fax number.
b) if you are in your home, then its a number of things: Fax machine not connected with phone lines properly is one big supect. Check your phone cables to make sure that the fax machine is properly connected.
Mar 05, 2010 | HP 1040 Plain Paper Inkjet Fax
I can make and receive calls, but I cannot hear anything.
Check Windows Sound mixer for application volume. Down in system tray at right side of taskbar double click sound icon for XP or click sound icon once and click Mixer for Vista. Look through volume settings for your phone application. Make sure it is not muted and volume is up.
Aug 21, 2009 | Google Android
I can only receive faxes not send when i try to send it just keeps ringing will not transmit
If you dial a number and just hear ringing that means the other end is not answering. Even if a person or answering machine picked up the ringing would stop. The problem is at the other end.
Mar 10, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
Dail-up server doesn't answer from my home phone
What if you dial the same phone number from your phone instead of the computer. Do you get a ring...static sound? It could be a problemw ith your phone provider
Mar 09, 2009 | Dell Latitude D600 Notebook
Problem with my hp 640 fax
once you dial the number you fax will automatically start sending the the Fax signal which sounds like short beeps. This is done so the receivers phone (when answered) will recognized the beeps and switch to fax receive mode.  If you are getting the recording that you mentioned above, that means the number you dialed was not successful in making the connection.  Once you dial the number you should hear the phone ringing followed by some churping noises when the other end answers the call... then other churping and gargle like sounds initially as the fax proceeds.
sounds like your are having trouble with the number you are dialing.
Hope this helps..
~enov8
Feb 24, 2009 | HP 640 Inkjet Fax Machine
Phone and answering machine are connected properly
I am still in need of a solution. It is not a 2 phone (cordless) it is 1 and know I have not solved the problem, I was hoping you would be able to help. I am not interested in purchasing anything other than what I already have.
Please help me resolve my problem, it doesn't sound like anyone has looked at or reviewed it. Thank you
Jan 07, 2009 | Uniden DXAI5588-2 Cordless Phone
Unable to confirm if set up
OBVIOUSLY, YOU DON'T LIKE TALKING WITH YOUR CUSTOMER'S, BECAUSE I DID RESPOND AND ASK THAT SOMEONE CALL, BUT TO ANSWER YOUR QUESTION ....
"NO" ..THE PROBLEM HAS NOT BEEN RESOLVED AND I ASKED SOMEONE TO CALL ME ...I'M NOT WILLING TO KEEP PLAYING THIS EMAIL TAG GAME LIKE HAS OCCURRED OVER THE PAST 3-DAYS NOW WITH YOU. AGAIN, IF SOMEONE DOES NOT CALL ME ON MONDAY, 1/5/09 BY NOON (PSR), I'LL BE WRITING YOUR COPRORATE OFFICE AND TELLING EVERYONE I KNOW ABOUT THE LACK OF QUALITY CUSTOMER SERVICE YOU DO "NOT" PROVIDE.
LOOKING FORWARD TO SPEAKING WITH SOMEONE AND THESE EMAILS WILL BE SENT TO THE CORPORATE OFFICE TO CONFIRM MY REQUEST AND YOUR NON-RESPONSE.
THANK YOU ...GAIL ...323.934.6578
Jan 03, 2009 | HP 640 Inkjet Fax Machine
Can't get ohio relay at all
I had the same problem with my Ultratec 1000. When not using the phone in voice only mode, I have to push the "dial" key before actually dialing the nbr.  Otherwise, the phone just sends baudot code for the nbrs you dial instead of touch tones. Once the call is answered the phone will switch back to baudot.
Apr 17, 2008 | Ultratec Uniphone 1140 Phone/Answering...
BROTHERINTELLIFAX775
TO NO MANUAL,
WHEN YOU DIAL A FAX NUMBER, AND IF YOU
HAVE DIALED IT CORRECT, YOU NEED TO
WAIT UNTIL YOU HEAR A COUPLE OR A FEW
DIFFERENT "CONNECTION" SOUNDS, AND
THE LAST SOUND IS THE FAX IS CONNECTED
TO THE FAX NUMBER DIALED SOUND.
IF I AM CORRECT, THE FIRST SOUND IS
A LOW TWEET LIKE SOUND, THE SECOND
SOUND IS A HIGH PITCH TWEET SOUND,
AND THE THIRD OR FOURTH SOUND IS
THE FAX SOUND, WHICH IS A SORT OF
STATIC-LIKE WHISTLING SOUND.
WHEN YOU HEAR THE FAX SOUND, THAT
IS WHEN YOU PRESS THE SEND FAXCIMILE
BUTTON.
I HAD A SIMILAR PROBLEM WITH A FAX
MACHINE ABOUT FOUR YEARS AGO.
IF THE FOREMENTIONED INFORMATION
DOES NOT HELP, YOU MAY WANT TO
RECONFIGURE YOUR FAX SEND AND
RECEIVE SETTINGS. REFER TO YOUR
OWNER'S MANUAL FOR TECHNICAL
DATA.
GOOD LUCK.
FROM
TEXASDUDE2008
Mar 12, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Motorola Mobility RAZR V3i Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
