Monitors
Problem for Monitors
Generic problem for all Monitors
Connecting my LCDTV upto my Computer
By Chelle81 on Nov 29, 2007
I'm trying to connect my LCD Monitor to my computer and when i follow the instructions in my manual it tells me to go onto source then menu but when i do this the pc box is not highlighted so cant get in to connect it what can i do
Same Problem
Jan 30, 2009
-   out of range ... changed computer to lowest resolution , still same error -   Guest
Jan 04, 2009
-   I am trying to connect my labtop to Hansol H750 monitor but the screen is blank, how do i connect them.
kyla -   Guest
Nov 20, 2008
-   show me how will connect from lcd to desk top
-   Guest
Nov 07, 2008
-   i am trying to hook my lcd tv to my home computer so i can use my lcd as a t.v and a computer i bought a vga cord and connected it to the back of the computer (not my laptop) and then to the back of the t.v when i go to input there is just a dash next to pc so i now have my tv hooked up to my cable box no problem but my tv wont show any computer not sure where i went wrong but i have lost the remote to my tv it is a sony 19" bravia kdl-19m4000 and the computer is a compaq any help will be appreciated thanks!!!-   itskissmett
Nov 05, 2008
-   I have apple comuters that automatically detect monitors, and it works fine for computer screens, but the LCD TV monitor recieves no signal when I connect. SO far I have used HDMI cable - standard cable for MacMini and MacBookPro that I have used to connect, but on the TV end there is a standard monitor connection. perhaps I need to try with a cable with HDMI at both ends?-   Guest
Best Solution
posted on Nov 29, 2007
Helpful)
Riziel
Rank: Wiz
Rating: 84%, 151 votes
Once you connect LCD Monitor to your Laptop! I am assuming your referring to a laptop hookup! Most PC's come with a function key which is labeled FN on your Keyboard next to the Ctl key. It should be in blue Print! You should be able to depress that Key along with I believe F8. this will transfer the image on to your LCD Monitor.
Was this helpful?
Yes
No
Solution #2
posted on Oct 22, 2009
Not Rated)
rtracey
Rank: Wiz
Rating: 83%, 23 votes
Riziel is correct. On some laptops instead of F8 you need to press FN + F2. Just look for the F key with a picture of a monitor on it.
Make sure you adjust the resolution before you try to output to the LCD. I would reccomend setting resolution to 1024 x 768 as this works with just about any display. Once you have a picture you can then set to the native resoltion of your screen. i..e 720p will be 1280 x 720 or 1368 x 768. for 1080p screens the resolution should be 1920 x 1080
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
Sceptre Agama III shows no video. It will briefly show Windows screen. Have checked the connection... (More)
Answer
Hi, I can't get all the screen options to show up when I push the monitor buttons. Also, I can't get... (More)
Answer
hi all,i have a problem with my acer al1917asm lcd monitor.that the screen goes black for 1 or 2... (More)
Describe your Monitors problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
in Van Nuys, CA
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
