Question about Epson Stylus C84 InkJet Printer
Printer not printing
Stylus C84 Epson. changed cartridge. Did head test etc. both with and without computer. Printer prints pg but with no ink. Pages comes up short. Read that other Epsons printers with this problem was tube disconnected. Is it the same for C84? If so how do I fix it? Please help
  • 1 more comment
  • daveprice Dec 04, 2007
    C84 ink isn't coming on the page at all, done all tests. Interestingly though all the the page comes out blank the ink cartriage levels are showing they are being used with each attemepted printout.
  • Teach1 Dec 11, 2007
    Did not use the printer for several months. Replaced all the cartridges. Nothing on paper when it prints. Ran all tests and cleaning utilities.
  • zeltenfreude Jan 05, 2008
    Nothing on paper after print job.
    Scholar:
  • 79 Answers
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Posted on May 01, 2008
SOURCE:
Will not print plank pages,even after cleaning.
check print head and head cable............
If ink flow change mainboard, print head, and head cable. if ink not flow change only main board
Jan 06, 2010 | Epson Stylus C84 InkJet Printer
Printing blank pages but just changed ink
check the print head and cable head. if it is ok you need to replace Main board. if they not ok replace all
Dec 19, 2009 | Epson Stylus C84 InkJet Printer
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help!
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Asker's Testimonial
" Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Comments:
Nov 12, 2009
- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
Good Luck :0(
Nov 12, 2009 | Epson Stylus C84 InkJet Printer
Pages are coming out completely blank...ink is fulll...i have cleaned the print head
I'm saying the same below!
By mclamemo on Nov 12, 2009 " " re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Help! +++++++++++++++++++++++++++++++++ I have learned from experience, that Epson2.gif does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Good Luck :0(
Comments: Nov 12, 2009- Funny. hahahahah,
lol :0) :0) :0) :0) :0) :0)
Asker's Testimonial " Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Oct 16, 2009 | Epson Stylus C84 InkJet Printer
Printer prints blank pages, have changed and installed new ink cartridges. wen through the head cleaning cycle bunch of times no luck. Any suggestions in fixing this?
Are you using Generic Cartridges? Pls See Below
Good Luck :0(
Oct 08, 2009 | Epson Stylus C84 InkJet Printer
Epson c84 printer not printing after installing new ink cartidges
Hi, Linda
You may buy cartriges of different producers.
Depending on producer on them can be or be not special yellow detachable labels.
These are an yellow labels must be removed from them. Then put cartridges back. And try to clean head 4-5 times. And check nozzle test.
Good luck.
Mar 06, 2009 | Epson Stylus C84 InkJet Printer
Ink printing problem
Did you remove the plastic from the bottom ofthe cartridge, if not do so and changing from vista to xp would change that probelm.
Jamiell
May 13, 2008 | Epson Stylus C84 InkJet Printer
Printer does not print
An ink supplier advised turning off the printer for 15 minutes, turn it on and try again. That worked once. Next time he suggested turning off printer, removing all cartridges, waiting 15 minutes, replacing cartridges. I couldn't do this without turning the printer back on and going through the replace cartridges routine. Now the nozzle check routine printed magenta and yellow only. I've run the head cleaner a number of times with no success.  Hope one of these suggestions works for you.
Jan 06, 2008 | Epson Stylus C84 InkJet Printer
BIG PROBLEM
If any of the ink cartridges are needing to be replaced, the Epson C84 will not print, you will have to change the cartridge, if you lift up the printer lid the carrier will stop at the empty ink colour.
Nov 14, 2006 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
121 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
