How do I change the Date and Time on my Brother Fax900 machine?
Thanks!
Sherri
Press teh MENU button. Go to INITIAL SETUP. Then to DATE AND TIME
I have a brother 2820 Fax machine which i require
1) to change the date & time
2) to change the fax & telephone number on the system.
Regards,
Tasha
Here is the manual
http://www.retrevo.com/s/brother+2800+fax+manual
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or
just by pressing the hook button. Once you have verified you have a dial
tone press the hook button again to return to the main screen or hang up the
handset. LCD should display the date & time
If you don't have a
dial tone make sure that the telephone line cord is connected on the fax
machine's Line jack. If you don't have a dial tone still connect it to
another working outlet. If you don't have a dial tone still connect a
working telephone on the wall jack to see if you'll get a dial tone. If
you get a dial tone on the regular phone then problem is either with the line
cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the
document that you want to send on the automatic document feeder which is
directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter
Fax No. & Press Start" Once you got this screen dial the fax number
and then press Start.
Hope this helps. Rate if it works.
Thanks!
