Question about RCA P46924 46" Rear Projection Television
No picture I have sound but the picture goes blank intermittently, no lines atl, just black. Any ideas? Vic
  • grizzly dog Dec 15, 2007
    i have a model p46924 that has sound but no video but guide plus menu works just fine
    Novelist:
    Champion:
  • 232 Answers
Common problem with that chassis and you need to take care of it now or set will fail and short several parts. Coil L4401 needs to be removed from set, scrape the leads (wax from insertion process) and re-install, solder it back in & you`ll be good as new.
Posted on Nov 29, 2007
  • Larry Eastman
    Larry Eastman Dec 02, 2007
    Vic, why did you rate my answer inappropriate ? You gave a symptom and I gave you a fix that I have personally done probably 50 times, I don`t understand ?
I tried to explain that the problem I am having is NOT with an RCA but with a Panasonic 27 Inch conventional television. I could find no other way to edit the problem once it was posted. Your answer was appropriate for an RCA but how about Panasonic? Would applericate a reply.Thanks.
Posted on Dec 02, 2007
SOURCE:
What is the likely problem, and is it likely to be expensive?
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 05, 2015 | Syntax Olevia 532H 32 in. LCD HDTV
Sony Blu Ray S350 plays well but have intermittent loss of video signal. Screen shows coloured background (yellow or white), audio continues to play then screen goes black then picture returns; this cycle...
It may be a problem in the digital section of the TV. If you find a part of the movie that blanks out, try rewinding back to it and see if it goes out again. It may also be the HDMI cable you are using. The blank out is often the result of the TV trying to adjust to the correct resolution for the program being played, and we need to diagnose why it is changing resolutions. Microwave interference and voltage fluctuations can also cause these issues.
Feb 25, 2011 | Sony BDP-S350 Blu-Ray Player
Picture comes on for 2 seconds then tuns to black screen Sound ok
Hi!
This more then likely a back light inverter board issue! It can be intermittent or just black an non responsive.
Feb 18, 2009 | Televison & Video
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Rear projection sony 51", comes
Sounds like bad picture tubes. please post a model number, also are you seeing arched lines going through the picture? these can useually be seen best on a blank input wiht a black background.
Thank You
Tim
Sep 11, 2008 | Televison & Video
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
Horizontal blue line
The intermittent horizontal line is cause by a loose solder connection in the vertical amplifier IC.
The IC is mounted on a heatsink nearby or around the flyback transformer.
The way to fix this failure is to add fresh solder where you see some brown spots on the circuitry that were cause by components getting hot.
Good Luck.
Jun 20, 2008 | Sharp 25R-S100 25" TV
42" RCA Projection TV - Sound good, but Picture goes out intermittently.
resolder the vertical output IC . bad solder there can make the CRTs blank for protection and you will lose the picture when the vertical drops out.
Mar 27, 2008 | Televison & Video
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
RCA P46924 46" Rear Projection Television Logo
96 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
