Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Red Cleaning Light won't turn off
I clean my unit religiously, but the red cleaning required light turned on and won't re-set. I have cleaned the unit, blown air into it, and even turned it upside down. How can I get the unit to re-set?
  • 13 more comments
  • Dreni Dec 01, 2007
    I have the same problem. The light stays red and I am scared to leave it running. I assume it won't function while the light is red
  • Cesar425 Dec 03, 2007
    Yup...and the Boost does not work. It's clearly not working but is getting power. Is there a way to reset it?
  • Shopgirl Jan 04, 2008
    We've cleaned the filer and the red clean filter light won't go off. When you turn the machine back on, it will not run because the clean filter light is on. The manual is useless. There doesn't seem to be a way to reset the light so that the machine will start cleaning the air again. I'm calling customer service tomorrow.
  • 67 PONTIAC Jan 29, 2008
    2nd QUADRA / SAME PROBLEM AFTER ONLY A FEW MONTHS OLD!
  • Skipperbob Mar 01, 2008
    I have two units, each about a year old. I have cleaned elements and taken the front gril off and cleaned the two vertical wires with beads on it as well as internal surfaces, but to no avail.
    The occurance of this problem seems to be correlated with having cleaned the carpets. While I waited until the carpets were adequately dried to use the Ionic Breeze Air Purifiers, I noticed that when vacuuming that there is a white powder which to this day is still accumulated in the vacuume filter.
    Don't know what this white powder is, but suspect that it may have buggered whatever senser it is that the Ionic Breeze is using to sense whether or not the elements are clean.
    Has anyone found a solution.
  • Anonymous Mar 04, 2008
    Same problem. I've cleaned the unit and "Cleaning Light" won't turn off, and other operating modes apparently blocked. Anyone have an answer???
  • Kosher May 17, 2008
    I will keep this short and to the point. I have the same problem except i own the MIDI. What can I do to fix this problem?
  • Anonymous May 19, 2008
    MIDI unit- red light does not turn off
  • Anonymous May 28, 2008
    red
    red light never goes off
  • Anonymous Jun 20, 2008
    Have cleaned everything. This is the 2nd unit since the first one did the same thing and they replaced it. I guess this is the norm for this company.
    This is my 2nd replacement unit and it has the same problem.
  • Anonymous Jul 03, 2008
    red light won't clear and unit doesn't work
  • blaisef1 Jul 25, 2008
    Red light flashes, unit doesn't work. refuses to boost. I cleaned it, took off the grills and blew it out with compressed air. Cleaned the conductor posts with mek.
  • Anonymous Jul 26, 2008
    Red light will not clear. Unable to rest unit. What can I do?
I just came across this site: http://www.infomercialscams.com/defenses/ionic_breeze
the first post from a person who just raves about the item suggested putting the grid back in after cleaning and holding it upside down for 30 seconds. I did this - actually did it a little longer because I was reading the rest of the posting. IT WORKED! I had tried and tried to get the red light off by cleaning it, but it didn't work. This must be way to reset it. When I first turned it on, it started to blink again, and then I turned it off and on again and it is working great. I AM SO EXCITED. I also turned it upside down and upright several more times after I held it upside down for the 30 plus seconds. I hope this helps!
Posted on Jul 28, 2008
Take it back. Hopefully it is inder warranty. I have had 2 units do the same.
Posted on Dec 12, 2007
    Problem Solver:
  • 12 Answers
If under 5 years should be under warranty and just got off the phone with them if you have cleaned it and it still does it probably a mechanical malfunction. Only thing on mine that works now is the light should be sending back after holidays though. Everytime have had a problem and think it comes from living in a very old high traffic house that causes mine to quit even though clean them, but probably not as often as I should.
Posted on Dec 22, 2007
2 Suggested Answers
SOURCE: Red Cleaning Light won't turn off
If the cleaning light stays red it is do to a failure of the nichrome wire sensor that detects deposit build up. This wire is locatied in the center where the grids are removed and easily broken. It runs from top to bottom twice. Look inside and if you see a loose wire that looks like a fine thread that is your problem. Not a do it yourself job.
Posted on Aug 29, 2008
Red light comes on after cleaning S1730 GP Sharper Image
Make sure filter is positioned correctly and fully seated.
If it does not come on with a clean dry filter it may be a faulty high voltage component.
Feb 05, 2012 | Sharper Image Ionic Breeze GP SI730 Air...
My unit keeps turning off, attention required red ligth is blinking, I just clean te unit
make sure not to forget cleaning the corona wires. i used light grade sandpaper and gently cleaned the wires as well as scrubbed the metal grids with scotch brite pads. the unit has been running normally .
Aug 01, 2010 | Sharper Image Hybrid GP (SI724) Air...
"Cleaning overdue" red blinking light after cleaning was done
Check that there are no fine pieces of lint that are bridging the plates or the ionizing wires, to ground.
Check the contact points of the collector cell and inside the unit.
The light is caused by a shorted collector cell and associated components.
Dec 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic breeze quadra s1857 Red light continues to blink needs cleaning even after cleaning. not filtering. help
Mine is a Pro-series Quadra. It needed better cleaning.
The front and rear plastic grill scome off (release catch at the bottom of each), allowing access to the central core. I cleaned it with a damp rag (let it dry before you turn it back on). Be very careful of the two wires running the length of the unit -- if you break these it will not work. I did, however, gently clean them.
When I restarted it there was an unusual smell for a few minutes, but all is working well again.
Apr 13, 2009 | Sharper Image Ionic Breeze® Quadra® Air...
Red light stays on continually.
Same problem : after cleaning thoroughly inside by removing the Front & Rear Plastic grid and the stainless blades, I also cleaned the 2 wires (very softly and carrefully, not to break them), but the Red light goes on after only few minutes :
Here is my last Solution :
1 - Turn on (Low position) although the Red ligt is on
2 - Release the Rear plastic Grid (or Front plastic grid, or both of them) : That stop the unit automatically
3 - Replace it and make sur it's well locked : the unit turns on automatically.
After that, my unit works well, no mor Red light.
But my husband will see if he can by pass the Cleaning detector, so we will not have this stupid Red light on anymore !
Good luck.
Feb 22, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Red light stays on
I had the same problem: Had cleaned it inside, taking off both grids, washing wire, etc. Still the red light blinking would come back on after a few minutes. So here's what I did next:
Take off the grids on both sides. Make sure the grids are clean with water and paper towels (lots of black) On the unit itself, wipe out the metal sides and all the plastic. Then, here's the KEY,
get out your computer cleaning canned AIR and blow it into the open unit and blow the air on both of the grids too. I first used a hairdryer to blow it out, but the canned air is much stronger and I got all kinds of little black particles out with it.
Put it up and down 3 times, plugged it back in and WALAA! The unit is back to working perfectly and no red light has come on again!
I'm sure this will work for everyone if you just get the canned air and blow out the unit and the grids too even though you've cleaned them!
Sep 02, 2008 | Sharper Image Ionic Breeze 3.0 Air...
"clean" light
Sharper Image was giving customers a small rebate for the product since it was proven to be ineffective for cleaning the air by Consumer Reports as well data by the EPA.
This has caused a mess for Sharper Image that they went into bankruptcy as a result of it. The Consumer Products Safety Commission is going to be making a decision on ionizers at the end of year since there are hazards in the air from using the devices. It could be that ionizers are no longer sold in the US next year.
The industry should have been regulated and unfortunately the government never did anything about it until Sharper Image and Consumer Reports went to court on it.
Jul 31, 2008 | Sharper Image Professional Plus Ionic...
After cleaning the unit, replace the grid into the unit. Hold upside down for at least 30 seconds to reset.
Jul 19, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
491 people viewed this question
Top Sharper Image Air Purifiers Experts
Marvin
Marvin
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
