What size video does Facebook allow? mine is 50.2MB 2 seconds and all it does is say done, show some green bars and keep repeating that over and over and over
i din't know what remote you are using. for mine, ther are 2 individual buttons to push. onre button at bottom changes picture size eg. wide, normal, movie etc. it repeats so just keep selecting if you go past your choice.
the button on the upper left says 'source' and this lets me swithch from dvd to tv to auxillary etc.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
check the file size facebook will only allow files up to a certain size also when posting videos be sure that you are under the video tab to upload (should be next to the upload pics)
Please convert the video to .flv or mp4 for mat using total video converter or any other converter u like then the size of the video will shrink and u can upload it on the FACEBOOK. 640 MB sized video cant b uploaded to facebook
Re: CP2025 cleaning at every possible moment
Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size:
Letter
Default Paper Type:
Plain
Manual Feed:
Off
Duplex:
Off
Bind:
Long Edge
Tray 1 Size:
Any size
Tray 1 Type:
Any Type
Tray 2 Size:
Letter
Tray 2 Type:
Heavy 111-130g
Paper Out Handling
Specify Time and Action
Paper Out Time:
0 Seconds
Paper Out Action:
Override
call sony even if your console is out of warenty i had the same problem a couple of months back and warenty was expired by a few months i called them and they gae me a refurbished ps3 free
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
I have this one and it works in a different way so this may help everyone struggling.
1. Turn off the earpiece if it isn't already on 2. Press and hold the power key - when it comes on in about 5 seconds, keep pressing the button 3. About 3 seconds later, the light should change from a steady pulse to a solid light, you can then release your by-now-sore finger 4. Start searching for the device on your mobile (or other device) 5. Pair it when found (if this doesn't happen automatically) and enter the passcode 0000 when prompted. 6. All done
Hope this helps those struggling with Rob's solution,
