Frigidare front load washer error code
I purchased this washer in 09/2005. By 05/2006 I had this problem and it was repaired. I think that the tech said it was caused by not using the correct type of detergent. The machine has not been used in several months. I recently hooked it up again and am now getting an error code "ddo". The lights all work. The door locks. But then nothing happens. Then about a minute or less later the error code pops on the screen and the machine beeps.
  • jwgibbons Dec 15, 2007
    I have a Zanussi Dishwasher Model No. DI 110 TCR/B. When I turn it on, the 4 cycle indicators flash & the machine beeps 6 times. Though I press the cycle buttons that are blinking, none select. After about 30 seconds, the machine beeps again. This happens continuously and the machine will not run.
    President:
  • 1,294 Answers
Could be "detergent drawer open". Try opening and closing the door shut. There is a magnet there which shows that the door is closed or open. Use front loading washing powders preferably.
Posted on Nov 30, 2007
SOURCE:
My frigidare affinity shuts down mid cycle , and has to be restarted many times in order to finish a load of clothes
Remove top of washer by removing screws in back of top. You should see the tech sheet. Use this to retrieve any error codes.
A common problem with these is a bad door switch. (The part the strike goes into. If this is the case you should come up with error code for it.
Mar 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Error code 20 Washer stops, beeps and is still wet. What's up? No error codes chart is found on frigidare website.
Greetings,
you need to go to your pump and clean it out..its probably full of change and hairpins and stuff like that....
Dec 14, 2010 | Frigidaire GLTF2940ES Front Load Washer
F 14 error code on whirlpool duet washing maching. repair man say it needs ccu. How can I replace it and where can I purchase the part? Can this error code mean anything other than bad ccu?
Remove the bottom front panel 2-3 screws at the very bottom. Inside there should be a tech sheet that will explain error codes and how to trouble shoot them on your specific machine. Replacing the CCU is not that hard but getting to it is tricky. See following link to video on repairing duet http://www.rakerappliancerepair.com/ApplianceLibrary/Washers/WashersLibrary.aspx
Mar 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
My frontload showing err 70
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on search
Step 5 your error code information is in the TECH DATA file there you can perform a full system check PLEASE READ ALL WARNINGS POSTED
Step 6 save all PDF files to a new folder name it FRIGIDARE for easy availbility.
Thank you and good luck.
Jul 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Fridgidaire front load washer
Step 6 Also check INSTALLATION INSTRUCTIONS for part installation or (WIRING DIAGRAM if you are qualified with electrical experience NOT FOR NOVICE)
Step 7 save all PDF files to a new folder name it FRIGIDARE for easy availbility for printing or viewing.
Jul 10, 2008 | Frigidaire GLTF2940ES Front Load Washer
Know how I get to the spot I need to clear out for an E20 problem with my Frigidaire washer?
Step 5 access and save or print the: OWNERS GUIDE, PARTS MANUAL, OPERATING INSTRUCTIONS, and TECH DATA
Step 6 your error code information is in the TECH DATA file there you can perform a full system check after clog is removed. PLEASE READ ALL WARNINGS POSTED
Step 7 save all PDF files to a new folder name it FRIGIDARE for easy availbility for viewing and printing.
Jun 08, 2008 | Frigidaire GLTF2940ES Front Load Washer
Error E10
Step 4 type in MODEL NUMBER and click on SEARCH
STEP 6 Also access and save, or print PDF files: OWNERS GUIDE, INSTALLATION INSTRUCTIONS, OPERATING INSTRUCTIONS, and PARTS MANUAL(These PDF files will help in replacing, repairing, and maintaining your machine.)
Step 7 save all PDF files to a new folder name it FRIGIDARE for easy availbility for printing and viewing.
May 21, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
280 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
