Question about GE Nautilus 24" Built-in Dishwasher
GE Nautilus 4800 Dishwasher/Shuts off/ No water draining out
- Power is okay. I reset the breakers anyway.
- It takes in some water (20 seconds), and then shuts off.
- does not drain any water through the dishwasher disposal connection
HELP!!
  • shillow Nov 29, 2007
    I have the same problem on a 6yr. old Nautilus DW. I pulled the DW out and got under it and manually pushed down the drain valve and it drains out just fine. I'm thinking it is a problem with the celinoid. When I run it and cycle through it it clicks on for a split second and off again. Seems like it should stay open to drain the water. I need to know how to test this part?
    Scholar:
    New Friend:
  • 67 Answers
It may be the motor start capacitor or the motor or the wiring to it. Some units have a built-in switch that shuts the unit off if the motor doesn't start turning after a short interval. However, if it drains it usually means the motor runs enough to pump it out. These units usually stop draining when the fill switch opens at the lower level.
Posted on Nov 30, 2007
SOURCE:
The water will not drain from the dish washer and there does not seem to be anything blocking the drain. I ran it through another cycle and now it is leaking water slowly. Is there anyway to drain this...
I would suggest removing and cleaning the filter sometimes debree and build up of small particals can stop it from draining. Clean the filter in hot soapy water and then replace it in the dishwasher and run the dishwasher through a cycle, this worked for me.
Jan 25, 2011 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher doesnt drain
Water dosent drain Is there a reset button???
May 15, 2010 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
How do i drain my ge nautilus dishwaher
Pour hot water into the bottom and force the timer to drain cycle. Keep doing this until the suds are gone.
Aug 18, 2009 | Dishwashers
Dishwasher drains but leaves behind about 1/2" of standing water
Water standing in the bottom of the tub is normal.
A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated.
Jun 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Our ge nautilus dishwasher has the lock light and delay light on and we can't figure how to reset
Unplug or switch off the circuit breaker for a couple of minutes. Sometimes, these machines are sensitive to power blips and just like your computer need to be re-booted.
Jun 15, 2009 | GE Nautilus 24" Built-in Dishwasher
Pdw7800 rests before completeing rinse and dry cycles
It might be a glitch in the dishwasher's computer memory. Try turning off the power at the breaker box for ten seconds or so. This should clear the memory. After turning the power back on, restart the dishwasher.
Nov 26, 2007 | GE 24 in. Profile PDW7800 Built-in...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
304 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Vitally Alcher
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
