Microsoft Windows XP Professional SP2
Problem for Microsoft Windows XP Professional SP2
Remove/delete "torrentsworld.net" remnant files from the desktop
By zwarriorx on Aug 12, 2009
Ok ... I have a solution to this problem that works under XP 32-bit, but am stuck as far as XP/Vista 64-bit is concerned, since I dual-boot with XP 32-bit and Vista Ultimate 64-bit
Solution under XP 32-bit >>> Download and install a utility called 'Unlocker' (latest version 1.8.7) from http://www.ccollomb.free.fr/unlocker/.
Select the problem files on the desktop, right-click and select 'unlocker' option from the menu. You will be asked what action you want to take; just select 'delete' and OK. Problem solved!
Unfortunately, the same can't be done under 64-bit, 'cos 'Unlocker' does not come in a 64 bit version. There is another utility called 'LockHunter' which is available in both 32-bit and 64-bit versions. Using LockHunter (as far as this particular problem is concerned), all I can do is right-click and select "What is locking this file?" to see the obvious. There are further options under this, but in this case they are grayed out with a message that says "there are no processes locking this file or folders" ... so I can't take any action to get rid of the files.
These problem files only come when getting torrent files (trackers), which I think originate from that site.
Btw, using the command prompt (even booting in Safe Mode or administrator mode) as I have seen someone suggest does not work
So there ... any one have a solution to this under 64-bit?
10x in advance.
Comments:
Aug 15, 2009
- I hope this is ok because I'm posting the solution to my own posting/problem (in case it helps anyone else) that a user from another forum provided (and it worked in this case) .... 1. Open up a command prompt (run cmd.exe from the Start Menu). 2. Navigate to the folder that the object resides in. 3. Run "dir /a /x /p" to display the contents of the folder, including hidden files (/a) and 8.3 filenames (/x). 4. Find the 8.3 filename of the object to the left of the regular, long filename. 5. Run "ren <8.3 name>" to rename the object, "del <8.3 name>" to delete it if it's a file and "rd /s <8.3 name>" to delete it if it's a folder. Note: If renaming to a long filename, make sure to enclose the long filename in quotations. If that fails, temporarily rename it to an 8.3 name and then rename it to what you want outside of the command prompt. Original credit needs to be given to this site that provided the info to solve this problem http://www.netfresco.com/tech/item-not-found/
Best Solution
posted on Nov 02, 2009
Very Helpful)
KINGYADAV
Rank: Apprentice
Rating: 100%, 1 votes
[Torrentsworld.net] - Avira Antivir Premium Security Suite 8 1 00 221 _FULL_.torrent DELETE THIS FILE
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 07, 2009
Very Helpful)
eskimo227
Rank: Apprentice
Rating: 100%, 6 votes
Hey guys, someone finally solved this annoyance.
In the command prompt, from the directory that the "undeleteable" file is stuck in, try this command:
del [insert start of filename here]* <---wildcard
The trick was that the file ends with a space which makes it hard for windows to deal with for some reason. Try this, it definitely works. I was stuck with one of those [Torrentsworld.net] files and...
del [Torrentsworld.net]*
...worked for me!!!
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #3
posted on Aug 12, 2009
Very Helpful)
Amnonk
Rank: Guru
Rating: 88%, 37 votes
If you can dualboot to Windows 32, you can delete the files from there - after all, it's the same computer and the same hard drive, and you should have access to all the files on it.
Alternatively, you could try using a Linux LiveCD (Like knoppix), but I think you'll be more comfortable doing it with Windows.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Microsoft Windows XP
Questions and Unsolved Problems for Microsoft Windows XP
Do you recommend Microsoft Windows XP Professional SP2?
Answer
Answer
Need help with setting for internet options
Answer
Can I install propellorhead reason 4 on more than one computer or do i need a license?
Answer
why free to download audio card??
Answer
can i load tech in a box free from my computer systemax tiger on line
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Windows XP...:
Top Operating System Experts
Rank: Guru Guru
Solutions: 1424
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Operating System Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
