Question about Samsung HP-R5072 50 in. Plasma HDTV
No problem just trying to find out what it is!
Oblong grey in color looks like it snaps over a coaxil cable opens like a hotdog bun the numbers on are (zcat2035-0930) it was inside a samsung 42inch plasma tv box when i opened it had no instructions as where or what it was any ideas?
  • 179 Answers
It is a choke,,some areas have interference that comes in on the power line..you clip it to the ac cord to help reduce the interference
Posted on Dec 01, 2007
My TV all of a sudden turned white and grey.
First, try to play DVD on your tv to determine if the problem is on TV itself. If the TV looks fine on DVD you have cable box connection problem if not you have faulty t-con board not bulb etc.
T-con is the responsible for colors and image graphics.
Dec 10, 2012 | Vizio VS42LF 42 in. LCD HDTV
CONNECTING A COAXIL CABLE TO THIS TV
it needs a tuner, use a digi box , good look
Apr 11, 2012 | Televison & Video
Passenger window- about 1/3 way down- went to close- hit power button- started up then window fell-
You need to have the power window regulator replaced. Very common in these cars. Its not an easy job. With a good service manual and some patience its not to bad.
Jun 05, 2010 | 2002 Chevrolet Impala
Setting up xbox live
ARRIS modem is a phone/hsi modem. What youll need to do is first turn power off on xbox then unplug the power supply from the back of the Arris modem and unscrew the coaxil/cable wire from the back of the modem for about a minute. Then plug in the power cord to the modem wait another half minute then screw in the coaxil/cable wire....wait for the lights to come back on make sure the online light is solid green not flashing and follow the ethernet cable (Looks like a thick telephone wire) and make sure you have that ethernet cable seated/snapped into the ethernet port on your xbox. Then turn the xbox on and do connection test. FINISHED..IF it's still not working make sure you have Internet service from your provider and if using a router bypass it at first see if you can get onto xbox live without the router. If you can with just connected directly to your arris modem without the router involved. If you do want to use wireless contact your router manufacture and or xbox support at 800-469-9269.
Apr 24, 2010 | Arris Touchstone 450a (CM450) Modem
How do I stop my hot dogs from looking bag coming from my steamer
not really discolor, does it looks like came out of water?
if so, that is because the steamer works. Steamer is cooking the food via water vapor and heat. For the dogs to looks like dog, you need to "dry out" the skin. pan fry, BBQ, grill, or any other metod you can to dry out the skin, then it should start to look like a dog.
Jun 03, 2009 | APW Hot Dog Steamer/Bun Warmer
Toshiba 50h12-reception problem with ant 1 & 2
the tv has a built in decoder. if its scrambled it may be on the wrong setting. try resetting tv to factory settings and see if it sorts its self out. if not it may need the av board changing as it has a fault with the decoder chip.
May 23, 2017 | Toshiba 50H81 50" Rear Projection...
Lexmark z53
You will need to do the following diagnostic tests to determine the exact cause of the error: · Remove the ink cartridges · Perform the self test (test B below) · Test the ink cartridges A. To remove the ink cartridges: Switch the printer on by pressing the green button. Open the front cover of the printer. The cartridge carrier should move to the center of the opening. Remove both cartridges. If the carrier does not move to the center of the opening, you will need to remove the cartridges by hand. Turn the printer off and remove the power supply cable (the small circular one) from the back of the printer. Open the front cover of the printer. Inside the printer, locate the silver metal carrier bar on which the print carriage slides. Locate the black rubber carrier belt above the carrier bar. This belt has tracks on its inner portion. Grab the top portion of the belt and move it toward the right. As you move this, the ink cartridge carrier will move to the left. Continue to move the belt until the carrier is in the center of the opening. Now pull both cartridges out. B. To perform the self-test: Disconnect both the power cable and the USB or parallel cable. After one minute has passed, plug the power supply cable (the small black circular one) back in. (This step is necessary to reset the printer.) Turn the printer off by pressing the green power button. Hold down the grey paper feed button. Turn the printer on by pressing the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the power light blinks twelve times while no cartridges are installed, there is a problem with the printer. If this is a new purchase, you can also exchange the printer at the point of purchase. If the paper went through the printer as if printing was occurring, you will need to do some more testing. Continue as instructed below. C. To test the ink cartridges: Open the front cover and insert only the black ink cartridge. Make sure that you push it back until it snaps into place. Close the front cover. If the light flashes twelve times, there may be a defect in the black cartridge. If not, proceed to the next step. Turn the printer off using the green power button. Hold down the grey paper-feed button. Turn the printer on using the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the light flashes twelve times, there may be a defect in the black cartridge. If a page came through with a black line, your black cartridge is working properly. Now you need to take the black cartridge out and perform the same steps with the color cartridge. If the light flashes twelve times, there may be a defect in the color cartridge. If a page came through with colored lines, your color cartridge is working properly. If one of the cartridges is causing the problem, you will need to replace that cartridge. If it is a new cartridge, please exchange it at the point of purchase. Good luck
Aug 30, 2007 | Lexmark Z53 Color InkJet Printer
Yellowish color
turn off the color and see if you have a good grey picture if not your grey scale is off and requires adjustment
Aug 26, 2007 | Hitachi 43F300 43" Rear Projection...
Samsung HP-R5072 50 in. Plasma HDTV Logo
42 people viewed this question
Jerry Greenberg
Jerry Greenberg
