Question about Kenmore 62702 Microwave Oven
Steams My Kenmore Microwave heats just fine, but when I open the door, regardless of what I have cooked inside, a billow of steam comes pouring out the door. I leave the door open for a few minutes until the steam disappates. Is there something wrong with it or is it safe to continue to use it?
  • breinholtfam Nov 01, 2008
    I have a kenmore microwave 721.80594401 and when i hit the start botton i don't hear the fan running but the microwave works fine. how do i fix the fan.
  • Kenmore Master
  • 9,098 Answers
It could be a problem with your cooling fan or hood fan not venting the cavity enough.
To help you most effectively, it's better to post your full actual model number. But I'll give you the general info for now.
If this is a countertop model, you should feel strong air flow coming out from the back.
If it's an over the range model, you should hear the internal fan blowing when you hit Start and see the steam moving around while it's heating.
If the fan is not blowing and air is not blowing or if the next system is not working or blocked, you will get more steam than usual and the magnetron will likely end up being damaged.
Some steam buildup inside is normal, but not too much. It's kind of subjective, but it's dependent to a lagre degree on that air flow.
Most newer models don't have any gaskets to worry about, but older models may have deteriorated gaskets which limit the air flow.
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer once we pose a final solution.
Posted on Nov 30, 2007
My microwave shuts off, black no power when ever I cook tv dinners, potatoes etc. after 2.5 or 3 minutes. After 10 minutes or so, power comes back on and it displays PF. lots of steam inside after.
Hi Kerry,
"PF" is power falure if you didn't aready know this. It sounds to me like the coolig fan might be running slow or there is blocked or restricted air flow through the unit. This cooling fan is only for the HV transformer and magnetron. Sometimes you may get air flow around the door but this is incidental. The PF tells me that the power is being interrupted either at the power source (wall outlet or circuit breaker) or the magnetron TCO is cutting out. It also could be a bad magnetron running too hot. As far as the steam goes, I usually just leave the door open on my microwave for 10 or 15 minutes to let the condensation evaporate.
Jun 25, 2015 | Hotpoint RVM1435 Microwave Oven
Microwave exhaust fan doesn't really exhause any steam out. Model 721.80042700
The fan is for cooling the magnetron, nothing else. Steam remains in the cavity which is why the door should be left open after cooking to allow the steam to evaporate.
May 30, 2017 | Kenmore 30" Microwave Combination...
Rust marks on inside trim
IF YOU USE THE MICRO WAVE ALOT WHEN YOU COOK SOMETHING THE STEAM FROM THE FOOD BUILDS ON THE INSIDE AND CAUSES THIS PROBLEM. THE HINGES ARE OPEN AREAS WHERE THIS STEAM CAN COLLECT. NOTHING TO WORRY ABOUT
IT'S JUST ONE OF THOSE THINGS THAT HAPPEN
Sep 15, 2009 | Samsung MW5592W Microwave Oven
I have a GE microwave with the message sensor error
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the macimum amount of time. Use Time Cook to heat for more time.
Thanks.
Jun 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs but does not heat food either with sensor or manual timing. Occasionall will displasy 'SENSOR ERROR'. Have closed door and pressed CLEAR/OFF per manual instructions, but still does not...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
Then let us know if the hard reset does not fix it.
INFO: On GE models, "SENSOR ERROR" appears on the display when:
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
If the reset didn't fix it:
When you hit Start to cook, do the inside light and turntable come on?
Any unusual noises?
Is it louder or quieter than usual?
Do you have the model number?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Sep 07, 2008 | GE Microwave Ovens
Microwave light
my kenmore microwave model # 66222, doesn't let the steam out, its ventilated so I know thats not the problem, smells like its burning then shuts off and doesn't come back on until its cooled off, this happened when cooking a Baked Potato, also when I cook something for over 5 minutes
Aug 13, 2008 | Microwave Ovens
Door Window steams up on Microwave
Is the internal cooling fan running? You should feel air flow from the grille in the front or back (as the case may be).
If it's just steaming up the inner face of the door, that's fairly normal, but if the steam is appearing inside the layers of the door, that is not normal.
Since it's new and you've got a warranty, I would call Emerson.
Nov 02, 2007 | Emerson MW8107WA Microwave Oven
Microwave Steams Up, Heats Up, and Shuts off!
first of all your mwave needs to be properly ventilated .the problem is your magnetron when heated the thermal cutof switch cutts out power to magnetron.works again when cool.change magnetron
Mar 20, 2007 | GE XL1800 1100 Watts Microwave Oven
Microwave turns on, but no heat or turntable movement
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure, but it may also be a broken switch mount. I have a text file called "doorsw.txt" which helps in diagnosing and repairing door switch problems, and a file called "safety.txt" which is of vital importance. It is at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 or at http://www3.sears.com
Mar 19, 2007 | Kenmore 62702 Microwave Oven
Kenmore 62702 Microwave Oven Logo
307 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
