Samsung LN-S4692D 46 in. LCD HDTV Logo
Posted on Aug 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Same "clicking" problem with 46" Samsung LCD...does not turn on.
My LCD started acting up after about 1 1/2 years...now it does not power up at all...just clicks. I actually bought a new/refurbished power board and replaced it but still same problem. I also found a pcb switch board (for the power button) on ebay...replaced that...still same problem. I had a friend (electronics guru) take a look at the original power board...he said that it looks fine...didn't see any real problems...even though I told him that the relay on that power board is definitely making the clicking sound. Not sure what to do now except buy a new TV.
  • 1 more comment
  • eastend18 Aug 12, 2009
    I had the main board looked at by a tech repair...he said it does not seem to have any problems...and the fact that I tested another main board in the TV with same problem shows that maybe the issue is with the inverter board...I haven't removed/tested that one yet...it is probably at the top (back) of the TV and much smaller than the main board, right?
  • eastend18 Sep 22, 2009
    sorry, not in the DC area...and I still have yet to determine the actual problem...I've tested/tried different ideas...nothing yet...I'm actually in the middle of working on replacing the LCD inverters (left and right)...I found them on ebay...I have to fix one of the connectors and then I'm going to replace them in the TV...while keeping my fingers crossed.
  • Sp Gupta Dec 19, 2013
    Some time back I got a 46" Samsung with the same problem. The main board was defective in this case. 5V line was showing short with the ground. Many a time power board is also found to cause this problem. Good luck to you.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
891
Points
With any luck you will have the same problem asa the rest of us : blown power board capaciters , remove the rear cover {20 screws} look in the middle of the back of the set with the cover {5 screws} removed from the power supply . Now look to the upper right cornerof the board in the middle of the tv there may be 1 or several capaciters leaking from the X shape on the top , this be be your problem match up replacements but source units that have a higher max voltage than 10volts 7 get them soldered into the board . I repaired mine that failed at 16 months for $4 in parts & it took longer to remove the screws than it did to affect the repair. If you are not conifident about soldering on your $2000 tv then take the board to someone for the job to be done , I would not advise this as a first soldering job , good luck I can't belive how common this is Samsung needs to step up ......
Ginko
Level 3:
  • Samsung Master 19,396 Answers
  • Posted on Aug 12, 2009
Ginko
Samsung Master
Level 3:
Answers
19396
Questions
25
Helped
8073249
Points
55462
As you will probably know , when the TV is clicking , that means that the protection circuit is on because a fault ad been detected.
If you already replaced the PSU and the control buttons, then grab a service manual and follow troubleshooting diagrams to test digital controller board (main board) and inverter board.
The manual can be ordered from Partstore or Vance Baldwin.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1072
Points
Http://www.youtube.com/watch?v=tK7zFBBU6p4&feature=related
follow that link,, you will save over $400.. so easy to do... i can take it to a computer guy and he will do it for $20 $25..
Anonymous
Level 1:
  • Posted on Sep 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
891
Points
0
Are any of you in the area because we have the same problem with the power button just flashing red but it won't power on. I live in the DC area and would pay for someone to fix it cheaper than a tv repair guy....
I have a 52" 1080p 120 Hz LCD HD Samsung TV that
You have a problem on your Power supply board, possibly a bad capacitor or loose connection. You can look hard at your power board and check for these things or replace it from places like shopjimmy.com or discount-merchant.com etc
2helpful
My samsung tv won't turn on , It just started to
Your Samsung LCD TV needs a new power supply. You can obtain one by part number from sites such as shopjimmy.com, discount-merchant.com or tristatemodule.com.
My samsung 46 LCD TV takes 5 - 6 tims to start?
Power supply board have dead capacitors.Know how to solders?Check these capacitors for puff up or burst open replaced these capacitors.Or buy and replaced the whole power supply board at Shopjimmy.com,Ebay.com.
1helpful
TV takes long time to turn on.
most likely the power supply board is starting to fail, soon it will not turn on at all.call 1-800-samsung for nearest service center.
4helpful
TV screen went blank and it began clicking, turning itself on/off repeatedly. Had to unplug from wall to make it stop. TV is only 2 years old and has worked perfectly until now.
the power supply board has failed. call 1-800-samsung for nearest service center. power supplies are usually $125.00 plus labor, 1 hour maximum to repair.
I have a 46 inch Samsung LCD model number LN-T4665F and I have been having issues w/ the power/ clicking sound! It used to turn on and clicked a few times now just clicks all the time and doesn't turn on...
1. It is not a two years old TV, but a 9 years old one.
2. The common problem of the symptoms is a defective main power supply, you may check to see that are there anny "Pup-Up" electrolytic capacitor on the power supply, if there is any, replace them, you may fix up the TV
Samsung 46" HDTV power keeps turning off after a period of time
Panal damage is a possibility however, you may also try to have a tech replace your mainboard since you have sound.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
