Question about Answering Machines
BT Response 75 - message
When anyone leaves a message on my answering machine, the recording ends with the message "The service requested is not available on this line". The caller doesn't hear this. Any idea how to stop this?
SOURCE: BT Response 75 Answering Machine "memory full" problem
We have the same problem, but there are no apparent batteries in our unit.  Is the 'Z1' component some funky battery and did you unsolder it?  Thanks!
Posted on Jan 29, 2008
0 characters
1 Points
Can you record your own message on a bt response 75
Your BT response 75 has 2 built in responses depending upon whether it is set to Ansaphone or Answer only. How to do it is all clearly described in the manual which can be downloaded from here:
and saved to your computer for future reference. It is in pdf format and can be read using Adobe Acrobat Reader. The page you require for reading about the outgoing message is p11 of he manual, which is p13 of the pdf file.
Hope this is helpful, if so would you please register that with Fixya
Dec 30, 2014 | BT Response 75 Plus Answering Machine...
My answering machine is displaying an A and won't let anyone leave a message on it. What should I do?
Your machine is set to the announce mode, where it only plays an outgoing announcement without taking any incoming messages. You want to switch it to the record mode, where it will record incoming messages. Since you declined to specify the model of your VTech system, I can't tell you how to switch it. I can only direct you to enter the model number into the search box here to download a copy of the manual.
Nov 21, 2010 | Vtech Answering Machines
When testing the outgoing message the volume seems
If you click on the above , go to p.11,12 on setting the volume .
I agree with everything you say the only thing I can add is you may not be setting the volume correctly see note on p12.
Hope i`ve helped.
Dec 10, 2009 | British Telecom Response 75 Digital...
Creating an Outgoing message that tells a caller to leave a messa
To Create Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
Please let us know if that was helpful enough.
Good Luck & Thanks
Aug 13, 2009 | NorStar Flash Voicemail Power Supply Only...
When simeone calls, it won't record their message
This was a new phone I was using,& didn't realize I had voice mail on it. When it rang 2 times, it recorded the message before I answered on the 3rd. or 4th ring, giving me a dial tone. It is all fixed now.
Thank you
Jeanie Girl
Jan 30, 2009 | Answering Machines
Says machine is full, but there are no messages on the machine
make sure you retrieve all messages . I mean you may have 0 new messages, but you have lots of old messages ,it may full too.
Otherwise, delete all message, try to record incoming message or record your personal greating. Make sure the record function work, record chip works as well.
Jan 15, 2009 | GE 29875GE Digital Answering Machine
Radio shack 43-3829 answering machine
Well, your machine might be broken, or you haven't set the little switch on the unit to ANS. The switch is on the side of the machine where the cables come out. But here are the instructions from the manual:
Recording Outgoing Messages:
Your answering machine has a built-in outgoing message, "Hello, please leave a message after the tone." You can use this message or record your own.
1. Hold the ANNC/DAY/<<, and speak clearly into the microphone, no more than 10 inches away.
2. Release the ANNC/DAY/<< when you finish. Your answering machine beeps and automatically plays back your recorded message.
*Your outgoing message must be between one and 60 seconds.
*If you record your won message but wish to revert to the pre-recorded message, press DELETE during playback of your outgoing message.
Nov 09, 2008 | Radio Shack 3825 Answering Machine
1188 answering machine
I have model no. 1188 bellsouth digital answering machine. If you have to leave a message, the message I recorded is no longer there, there is a generic message saying please record your message. How do I go back and record my voice with my message. I cannot find my original manual.
Oct 07, 2008 | BellSouth Digital Answering System 2006C...
Nov 09, 2007 | Answering Machines
Bang and olufsen BEOTALK 1200
Make sure answer machine function is turned on. Bottom right button.
Make sure an outgoing message is set. Should see a <-> arrow in the display screen. If not, press the <-> button. To record outgoing message... the press the middle button; record out going message; press middle button. Wait a few seconds and you should be set. Hope this helps
Aug 28, 2007 | Bang and Olufsen Beotalk 1200 Digital...
Answering Machines Logo
46 people viewed this question
Top Answering Machines Experts
Are you an Answering Machine Expert? Answer questions, earn points and help others
