Canon NP 6551 Black and White Copier
Problem for Canon NP 6551 Black and White Copier
How do you detach the sorter from a canon np 6551.
By beth681 on Aug 12, 2009
how do you detach the sorter from a canon np 6551. I've removed the screws and unplugged it. Is there a disconnect button or switch - I can see where it is connected with a metal "finger" but I can't get it apart.
Solution #1
posted on Aug 26, 2009
Not Rated)
tswiercinsky
Rank: Guru  Canon Office Equipment  Expert
Rating: 88%, 326 votes
If you can remove the top cover from the sorter, you will see what holds the sorter to the copier. There are two brackets with 1 screw each. The screws are vertical into brackets. After removing both screws, each bracket will pivot away from the copier to free the sorter. Hiope this helps. PS. 1 bracket towards front, 1 bracket towards rear.
Was this helpful?
Yes
No
Popular Solutions for Canon NP 6551 Black and White
Questions and Unsolved Problems for Canon NP 6551 Black and White
Do you recommend Canon NP 6551 Black and White Copier?
Answer
Answer
jika copy melalui baypass atas,meskipun ditambah tinta,hasilnya bersih tidak kotor,tapi bila dicopy... (More)
Answer
We close the stack bypass, but it still tells me to close the stack bypass cover. I found the... (More)
Answer
I ave a Canon NP-6551 copier. I was working, but it had a paper jam that I cleared, but now it is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon NP 6551 Black and White...:
Top Copier Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
