Question about Gaggia MDF Electric Burr Grinder
How long should it take gaggia mdf to grind?
Hi - i just bought a MDF and tried it this morning - i filled it with beans, switched on at position 2 - nothing happened except the motor came on. no grounds came out. i then switched motor off and on again and moved the setting to 5 with the motor running. left it about 15 seconds and there was nothing at all in my dosing collection tub. Any help much appreciated.
  • caza1471 Dec 04, 2007
    Hi there - thanks for this - I tipped out all of the beans and gave the unit a bit of a shake - refilled with beans, switched on and got a completely different noise from the motor - and grinding was perfect. Thanks for all of your help!
  • 833 Answers
I'm not familiar with this exact model but the problem may be either packing in the unit...since it never worked...or that the beans have jammed the unit in such a way that none are feeding to the burr. Usually, there is a way to remove the top half of the burr after removing the beans. Brush out the area and reinstall. The instructions that came with the unit should be of value. By the way, on some of these units, if the cup isn't correctly placed, it may prevent the burr from receiving flow. Enjoy!
Posted on Dec 03, 2007
SOURCE:
I have a Gaggia burr grinder, Brevetti Gaggia SA Model MDF, s/n 7262. The handle that you flick back and forth to let the grinds come out broke off inside the unit.fixable? 707=837-8916 Thanks Anne
Look inside the grinder, The lever is attach to a SPRING .
May be the lever is disconnected (unhooked) from the spring.
AND YES IS FIXABLE.
It cost you about $15-$30 for the parts.
Jan 15, 2011 | Gaggia MDF Electric Burr Grinder
How do you change the grind on a gaggia coffee grinder?
if it is everything in order you change the grind buy rolling the plastic container of coffee beans(container commands to upper burr holder. If it doesn't go easy than disassemble container and unscrew the upper burr holder, carefully when it comes out, you have some pins and springs from below. do not loose or displace them.
Jan 03, 2011 | Gaggia MDF Electric Burr Grinder
How do you adjust the size of grind with a gaggia grinder
The is a little lever you push up by the bean hopper. Then rotate the bean hopper to change the grind.
Apr 20, 2010 | Gaggia MDF Electric Burr Grinder
How can I clean my Gaggia burr coffee grinder?
For parts you can see, use an artists paintbrush. If you want to clean the internals, grind some panko breadcrumbs or raw rice grains, then run some coffee through it a few times before using.
Dec 10, 2009 | Gaggia MDF Electric Burr Grinder
No cream on the espresso when dispensed
I was having this trouble with Lavazza beans and Morrisons (horrible) beans. I switched to Formula 6 from James' Gourmet Coffee on the internet and every cup has a great crema layer and good taste.
With the old beans I could get an occasional good cup, it seemed this was more of a problem if the machine had been switched on for a long time before making the cup. I use a Gaggia machine with a Gaggia MDF grinder on 8 or 9 setting, with the new beans I now get a great cup all the time so I'm going to try more the James' range!
Nov 05, 2008 | Gaggia Tebe Espresso Machine
Can't disasseble burr set
take an oil filter remoover for cars(the model with 3 legs and gears will do better job). 2 man required one holding grinder other one start turning left and right the upper holder(during turning hold down the brake pin.) it is bit boring and job wich requires patience. but i think you will manage it
here is the diagram:
http://www.partsguru.com/images/Img844.jpg
Jul 12, 2008 | Gaggia MDF Coffee Grinder
Gaggia coffee
Do you prime the machine when you connect it to power?
Feb 01, 2008 | Gaggia Coffee In White, White MDF...
MDF very coarse grind
Several possibilities loom:
1. Same burrs for 25 years? don't be cheap replace them!
2. Dirt in the threads of the burr carrier, or the threads that recieve it?
Let us know what works
Dec 18, 2007 | Gaggia MDF Electric Burr Grinder
It could well be gummed up with years of coffee bean residue
Very simple to take apart. There are two screws holding the cannister. They are hidden under 5mm round rubber covers that you have to pry off. Then remove the two screws holding the plastic cover. Mark the position of the numbered dial relative to the brass burr assembly then remove it. Once exposed, you should be able to figure out why it is locked. Scrape away as much gunk as you can.
Aug 18, 2007 | Gaggia MDF Electric Burr Grinder
Gaggia MDF Electric Burr Grinder Logo
211 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
