Question about Canon PowerShot SD110 / IXUS IIs Digital Camera
Will not Focus anymore
My Canon A560 worked great one afternoon- changed the batteries and now it will not focus????  I'm sure it was not dropped or any other trauma.  I've taken out the batteries and replaced them with new ones.
Any ideas before I send it to Canon to get it fixed?
Camera just stopped focusing properly!! when you use the zoom you can see the focus is good but as soon as you stop zooming one way or the other the picture goes blurry.
One more thing when i switch it on the first picture i take is almost in focus and gets worse from there on.
could it be the auto focus is out of alignment? have tried a factory reset and messed with settings to no avail.
Any help greatly appreciated as i gave the camera to my mum as a present and this started a few weeks later.
  • marcusIT Nov 29, 2007
    I looked on canons website for troubleshooting and it seems there is a recall on my model for faulty ccd sensors which cause blurred focusing. I have been very careful with the camera and never dropped it but as i live in a warm country it is likely that the heat has affected the sensor.
    Genius:
  • 2,985 Answers
Thisdoes seem like a drop or bump- it does not take much to put a digi cam out of kilter.
Look lie it will have to go back for a repair job
Posted on Nov 29, 2007
Nikon Nikkor 50mm F/1.4 D SIC AF will not auto focus anymore after drop
Hi Bob.
This lens does´nt have an internal focus motor, this only works with an in-camera focus motor. So, if it is stuck after drop, there is a bend over the focus barrel. This means the manual focus will not work neither. If manual focus works normally, there an electronic problem at the PCB (broken element).
Oct 27, 2015 | Nikon Cameras
Our Canon Powershot SD 780 is having a focus problem.
This might be a problem with the lens, I'm not exactly sure but I will get you in the right direction. There's a great site that just specializes in these Canon Powershot problems and they're terrific to say the least. If you go to camerasandparts.com you'll see your exact problem there for the canon powershot sd780is model. That should get you in the right direction to fix this problem. I really hope you can get help with this.
Feb 05, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Canon A560 dropped.when the cam is on lens wont retract anymore
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 02, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
The focus lens was hit by a basketball and it won't take pics.
Have you tried a different lens on the camera almost any lens with the same mm size will work. If it still does not take pictures with another lens. You should take it in for service.
Dec 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
My camera lense will not focus automatically or manually.
There is no battery in the lens.  The lens receives power from the camera. Whether or not the lens is getting power, though, you should be able to focus manually.
When you say you can't focus manually, do you mean that you can't turn the focusing ring on the lens, or that when you turn the ring the image does not come into focus?
If you decide the lens needs to be repaired, I recommend sending it to Canon.  You can go to their website (canonusa.com if you're in the US), click on support, and follow the links.
Dec 20, 2008 | Canon EF 70-300mm f/4.5-5.6 DOIS USM Lens
Camera is out of focus
Make sure its on auto focus instead of manual. Also make sure the lens is fully extended
May 12, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Pictures out of focus suddenly
Make sure the lens is clean and does not have greasy residue on it.
May 07, 2008 | Sony Cyber-shot DSC-H5 Digital Camera
Canon EFS Lens question- please help!!
Make sure that the switch on the lens is set to AF. If that doesn't work, you may have a faulty lens. The EFS 18-55 is not a high quality lens.
Mar 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Lens auto focus sometimes does not work.
First make sure contacts on lens are clean ( see enclosed pic #2 ) . If this does not solve the problem the ultrasonic motor may be faulty pic #1.( sometimes switching on but sometimes not , will have to be replaced , unless there is a bad connection between the motor and lens pc board )
Nov 26, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon PowerShot SD110 / IXUS IIs Digital Camera Logo
207 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
