Question about HP Photosmart C7180 All-In-One InkJet Printer
I am running Windows Vista and using the HP Photosmart C7180 wirelessly.
When I scan to the computer all the images have lines of colour running from the top left corner to the bottom right all over the scans. It is more obvious on blacks and dark blues as here it obviously shows up more. Any ideas ????
Also the image on my computer and the lcd on the printer are not the same as the printed photo, this comes out much darker. In fact pinks come out more red and white are tinged green, again any ideas????
  • 417 Answers
Hi try coping a document from the machine and see if the copy comes out with these lines. If it does then the machine scanner unit is faulty and will need replacing. If not then the likely thing is that the printer device drivers are incorrect or faulty. reinstall the drivers or download a up to date driver from hp.com for the other printing darker try changing the graphic processor mode in the driver. Goto printers and faxes right hand click on the printer icon and select properties.
Once in properties select the advanced tab at the top of the windows within this tab at the bottom select print processor. Once in there choose another graphic mode OK close and test if no improvement select a different one and so on until improvement is achieved. if no improvement then reinstall the drivers if you haven't already.
Hope this helps
Thanks J
Posted on Jan 19, 2008
Using my F380 all in one, how do I scan to my
Scan an image
You can start a scan from your computer or from the HP All-in-One.
This section explains how to scan from the control panel of the HP All-in-One only.
To use the scan features, the HP All-in-One and computer must be connected and turned on.
The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One.
To scan to a computer
1. Place your original print side down on the left front corner of the glass.
2. Press Scan.
A preview image of the scan appears on your computer, where you can edit it.
3. Make any edits to the preview image, and then click Accept when you are finished.
To stop scanning ➔ Press Cancel on the control panel.
If this doesn't work for some reason you should also be able to scan using windows camera and scanning wizard, the link will show you how if you have XP, just scroll down past the "how to print" section.
http://www.microsoft.com/windowsxp/using/setup/hwandprograms/printfaxscan.mspx
or this if you have Vista:
If you cannot find the scanner wizard it could be because your version of vista doesn't have it, I'm not 100% but I think it was only packaged with the business version of vista.
If this is the case then you can download a free program called IrfanView from there site: http://www.irfanview.com/
Click the Start icon. Click All Programs .
Click Windows Photo Gallery .
Click File and then click Import From Scanner or Camera .
Click Import .
Click Scan .
I hope that helps..
Regards
Mike
May 26, 2010 | HP DeskJet F380 All-In-One Printer
Have a HP4180 deskjet printer that also scans. How to get images in the computrer?
The user manual that came with the printer should explain how to do this.
See extract below
Scan an image
You can start a scan from your computer or from the HP All-in-One. This section
turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software
1. Load your original print side down in the right front corner of the glass.
2. Press Start Scan.
3. Press OK to select the default application to receive the scan, or press to
select a different application, and then press OK.
4. Make any edits to the preview image, and then click Accept when you are
finished.
Dec 19, 2009 | HP Office Equipment & Supplies
I scan a document and then I click on
I suppose you should have some software running on your system to accept the file.
Check the user guide.
Scan an image
HP All-in-One overview
Note
2. Press Start Scan/Reprints.
finished.
Dec 19, 2009 | HP Photosmart C3180 All-In-One InkJet...
Scanner won't allow me to use scan to button
To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software must also be installed and running on your computer prior to scanning. To verify that the HP Photosmart Software is running on a Windows computer, look for the HP Digital Imaging Monitor icon in the system tray at the lower right side of the screen, near the time.
NOTE: Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
Dec 09, 2009 | HP PhotoSmart C4385 All-in-One Printer
HP Photosmart c7180 unable to scan since Windows 7 computer
go to following location and try to scan and tell me if it is scanning fine or same issue.
c:\program files\hp\digital imaging\bin in bin folder locate following files. /* in 64bit operating system inspite of program files look into programe files(x86).*/
1.> hpqscnvw
2.> hpqscnappi
3.> hpqdstcp.
4.> hpqgrpky.
double click on any of these it will start scanning.
Nov 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
Driver for Hp Photosmart C1783 compatible with With windows vista
get the Toshiba web page find your model and download suitable for win vista
the model c7183 is in the c1780 family so the driver and software will be the same for c7180 set of units
Nov 12, 2017 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C7180 not scanning
I had this very same problem yesterday & solved it, after about 4 hours, with a clean install!!
Check my "solution" post at another question where I explained it in detail.
Jack
Dec 29, 2008 | HP Photosmart C7180 All-In-One InkJet...
Weird situation
Did the problem start after a Vista update? That's when mine started...
Oct 04, 2007 | HP Photosmart C7180 All-In-One InkJet...
Scanner
Hi damirish I have also been experiencing problems with the Scan To Computer button. I am currently in dialogue with the HP "head technician" who is due to ring me tomorrow. I will let you know what my resolution is. Basically, my problem is that my network (I use a netgear router) and have one wired (XP Pro) and two wireless PCs connected to it - one Vista laptop and one XP laptop. For some strange reason, the wired PC is happily displaying the correct Scan to file, Word etc functions yet my two wirelessly connected (Not the the printer itself but via wireless router) PCs appear multiple times and when I try to scan something to these two laptops, I get all kinds of errors. Even after running the HP clean-up tools and rebooting and reinstalling the HP software (32 bit) I now am faced with problems whereby the C7180 is not even recognised by the HP "Solution Center". Sadly, despite it's marvellous printing quality, I am thinking this unit is going back to the HP factory for some serious overhauling. Again, I'll let you know if there is a resolution and hopefully HP will investigate why the Scan settings are so faulty. Regards Andrew from Adelaide, Australia
Sep 04, 2007 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C7180 All-In-One InkJet Printer Logo
171 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
