Question about Panasonic SC-HT680 System
Suround speakers and center speaker is not working
My subwufer is working and my two front speakers are working...but the two tall surround sound speakers and the center speaker is not..
  • jmorgan77437 Nov 30, 2007
    my system has the same problem but mine is a sc-ht720 rt,lt,subwoofer work but the others are dead also. any help would be great.
  • uaithne Dec 28, 2008
    I have the same problem. My l and r speakers work as does the woofer. However the two surrounds and centre are silent. They used to work when I installed it first, but had to dismantle to put in new floors and now cannot get it going.
Well you can change the setting to hear from different speakers. Play with it you will hear the front on one setting then all 5 on another
Posted on Feb 29, 2008
Should all the surround sound speakers be working when I am watching satelite TV? Mine do not, just the front left & front right have sound.
All speakers should be working. The display on the Sony unit will tell you which speakers are enabled with a box illuminated and each speaker that is decoding with the speakers abrevation eg SL for surround left also illuminated. If these are not displaying then you need to check your playback mode. If play back is set to 2CH you will only get the front speakers. Try setting play back to AFD ProLogicII, Movie, or Music. If this does not get the speakers running then check the speaker configuration in the setup menu. It should be set to 5.1, if not set it and press enter to save it. If this is setup correctly then try the level settings in your menu. Each speaker has a setting that can be adjusted up or down to effect the loudness of the speakers. If this does not do it then check the connectons at each end of the suround speakers ie, at the receiver and at the speaker.
Dec 02, 2010 | Sony STR-DE897 Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Can't get surround sound while playing the PS3. The surround works while watching cable
your suround sound system has been wired up so only cable plays throgh speakers
does your tv have a audio out RCA jack?
if so then connect the home theater to that
i cant help anymore because i dont know the suround sound model number ot what tv
Jan 11, 2010 | Audio Players & Recorders
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
SURROND SOUND
i would suggest alpines new 5 channel suround amplifier that has dolby 5.1 decoding and you will also have to have a head unit that supports 5.1 surround sound which as far as i could tell are only indash dvd players you will also need to purchase a center channel speaker as well
you can follow this link to the alpine amp
http://www.crutchfield.com/p_500MRAF350/Alpine-MRA-F350.html?tp=115
hope this helps
sincerely
justin
May 17, 2009 | Car Audio & Video
Only 2 speakers working
on your computer if you go to
  • start
  • control panel
  • sound and audio devices
  • click on change the speaker settings
  • click advance in speaker settings
  • and change it to 5.1 suround sound
Apr 11, 2009 | Audio Players & Recorders
Only Direct sound works good, and only two speakers
Some sound fields have reverberant effects that need adjusting so the levels become audible, such as in "stadium" mode. While playing one of these sound fields, navigate through the speaker setup menu and make adjustments to the "effects" percentage, and levels. Be aware however, that only in 4 channel stereo mode will your surround speakers produce sound 100% of the time. Also, in any form of Dolby Pro Logic mode you will hear more sound from the surround speakers originating from stereo source material than from monoaural material...example, a television station broadcast in stereo versus mono.
Mar 31, 2009 | Sony STR-DG710 Receiver
Kenwood KA-994 Amplifiler no sound from rear speakers.
SOUND FROM YOUR SURROUND SPEAKERS COMES BY BECAUSE OF PROCESSING THAT TAKES PLACE IN YOUR SURROUND CIRCUITS. IF THE SURROUND MODE IS ACTIVATED AND U GET NO EFFECT AND U SURE YOUR SURROND SPEAKERS ARE OPERATIONAL AND FULLY FUNCTIONAL. THEN THE PROBLEM LIES WITH YOUR SURROUND DECODING IN YOUR UNIT. REFER TO QUALIFIED SERVICING AGENTS.
Oct 08, 2007 | Audio Players & Recorders
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
Panasonic SC-HT680 System Logo
1,023 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
blanqui2000
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
