Using same phone line that was used for dial-up, which still works.
Never had DSL before.
House wiring checked as was all other new wiring.
DSL light on SpeedStream 4100 flashes red instead of steady green.
I connected to phone plug in outdoor interface box and got same result.
Have two Ethernet plugs on Dell computer; I get same result. I believe they both work.
All other test restults on AT&T Technical readout page say "pass" or "skipped".
hi,there are a lot of possibilities y ur dsl light wont stop flashing red, 1.could be hardware failure,2.defective lead light for dsl,3.or line issue on the network...i strongly recommend that you contact your isp or att provider so that test would be done by their tech support,...basically you have checkd all inside wirings n as you have said you even tested the nid already...have you tried changing the dsl cable or phone cable? have you tried using another modem? were you using a filter for your dsl? you have to consider also other emi/rfi or electronic interference....but most probably you might try upgrading your modem n see if your gonna get a steady dsl light...the ethernet plugs has no effect on the dsl light...its just the cable connection or line issue or defective modem...i hope this will help, pls feel free to ask if you need further astnce...
Comments:
Dec 01, 2007
- hi just for additional info, i believe for speed stream support is already limited since its one of the oldest modem for att/bellsouth. you might wanna check with your isp if they could upgrade your device for free, anyways you are a customer...
I have a siemens 4100 modem and a lynksys router. They were working fine until I switched the pc to...
(More)
I have a siemens 4100 modem and a lynksys router. They were working fine until I switched the pc to the laptop, now, the internet light will not come on. If I directly plug the modem to the laptop, all four lights are lit. When I plug in the router only three lights are lit. I have tried everything.
I am trying to use my dsl modem with a wireless g routere but once it is hooked up my modem light...
(More)
I am trying to use my dsl modem with a wireless g routere but once it is hooked up my modem light just continues to blink
no internet light..every thing else working..i reset...unplugged and plugged up every thing the...
(More)
no internet light..every thing else working..i reset...unplugged and plugged up every thing the right way....im thinkin its somthing to do with at&t
internet explorer flashed turning off your comp.to install new up dates when finished no service...
(More)
internet explorer flashed turning off your comp.to install new up dates when finished no service flashed, lights not working on modem are ethernet, internet and aactivity
