Question about Sony KV-27XBR45 27" TV
Delay to see the picture
Start a week ago, the delay to see the picture when I turn the TV on,
take more and more time every day. Start from 30 second (a week ago) to more than 2 minutes today, please advise.
Thanks
[email protected]
I have the same problem, though it takes a *lot* longer for the picture to come through -- sometimes 10 minutes. Sound is clear as soon as the TV and cable box are on, but the picture can take several minutes to appear. Once it appears, it seems to be fine.
    Problem Solver:
  • 7 Answers
Your power supply is going south, I have an old sony with the same problem. The voltage level drops and does not have enough 'kick' to start. It will work better when it is warm. The module will need to be replaced.
Posted on Dec 28, 2007
SOURCE:
Nikon D3100 shutter "problem"?
Are your pictures properly exposed and are they sharp or are your pictures degraded? Is that 1/3-second you describe a delay between the time you push the shutter release and the time the picture is taken or somthing else? Check to make sure you're in the proper shutter release mode (slider switch to right of the mode dial). Also, your self-timer may be turned on. Your camera allows you to set a 2 or 10 second delay from the menus. If it is set to 2 seconds and turned on, it might seem like a 1/3-second delay. If that doesn't help, you camera is covered by Nikon's warranty. Contact Nikon Service at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
Aug 27, 2012 | Nikon D3100 Digital Camera
GE Model WCVH6800 keeps pausing mid-cycle. I understand how to run the diagnostic but can't seem to get it to work. I unplug for 30 seconds and hit signal, delay, signal, delay but upon hitting the...
It stumped me first time. You have to unplug it, plug it in, then press signal-delay-signal-delay with in 30 seconds. You don't push any othere buttons first. Then it will lock the door, spin the drum, and go into troubleshooting mode.
Sep 24, 2011 | General Electric WCVH6800J Front Load...
Entry delay is set correct but I want it to call out more quickly when the alarm actually goes off. It seems to wait too long. Do the entry delay and the actual alarm call out delay always the same?
Installation manual is here:
http://www.sdilink.com/GE%20Manuals/Simon%203%20Install.pdf
Programming starts on page 17.
Dialer Delay is option 17 on page 29. It's default setting is 30 seconds.
To set Dialer Delay, press:
1.Add
2.Option #
3.17
4.Use the numbered keys to enter the time 005 -
254 seconds (all entries must be 3 digits).
5.DONE
To turn off Dialer Delay, press:
1.Delete
2.Option #
3.17
4.DONE
Hope this helps.
May 10, 2011 | GE Security Simon 3 Wireless Home Security...
I just purchased a Kodak Eastshare c182 and I would like to know how to take time delayed pictures.
Manual:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg01041/C182_xUG_GLB_en.pdf
Page 11
Using the self-timer
Use the self-timer when you want to be included in a picture, or to ensure a steady
Shutter button press. Place the camera on a tripod or flat surface.
1 In any picture-taking mode, press the Info button to turn on the shortcut icons.
2 Press to highlight the self-timer icon. Press to choose a setting:
10 seconds- A picture is taken after a 10-second delay (so you have time
to get into the scene).
2 seconds- A picture is taken after a 2-second delay (for a steady, shutter
release on a tripod).
2 shot- The first picture is taken after a 10-second delay. A second picture
is taken 8 seconds later.
3 Compose the scene. Press the Shutter button halfway, then completely down.
The camera takes the picture/pictures after the delay.
Use the same procedure to take a 2- or 10-second self-timer video, but press the
Shutter button completely down.
Mar 18, 2011 | Cameras
I have a JVC G40 DVD home theater system and when I play DVD's the voice and picture don't match up. Specifically, Peoples lips move and then a second later what they say is heard...how do I fix this?
When viewing on Digital TV:-
Sometimes Audio and Video signal can not be transmitted simultaneously due to additional process time for the video signal compared to that of the audio signal.
Often video signal takes more time than the audio signal to convert from analogue signal to digital signal in the Digital TV.
It may result in mismatch of the picture and sound.
In the TH-G30/40's HD AV Sync menu, you can adjust the audio signal delay for simultaneous AV signal transmission
1. Delay time can be varied in 10msec steps.(0 to 300ms)
2. Delay time is different between TV Brands.
So you need to adjust the delay time for correct lip-sync.
The adjustment is listed in the instruction book page12
Jun 26, 2010 | JVC TH-G30 Theater System
How do i turn on the auto timer?
Hi, Follow these steps:
1. In any Still mode, tap Settings to open the Settings panel.
2. Tap Self-Timer/Burst repeatedly, until the desired Self-timer icon appears at the bottom of the LCD: 10 seconds—A picture is taken after a 10-second delay (so you have time to get into the scene). 2 seconds—A picture is taken after a 2-second delay (for a steady, auto-shutter release on a tripod). 2 shot—The first picture is taken after a 10-second delay. A second picture is taken 8 seconds later.
3. Compose the scene. Press the Shutter button halfway, then completely down. The camera takes the picture/pictures
Apr 13, 2010 | Sony Cyber-Shot DSC-W5 Digital Camera
Does the FE-340 camera have a time delay feature so that we can take our own picture?
Please look for clock sign on buttons to turn on-off timer function.
Press clock symbol button to turn on timer function, press shutter button to start timer (10 seconds delay) to take picture.
Mar 14, 2010 | Olympus FE-340 Digital Camera
Strange delay.
I'm having the exact same strange delay problem as you.
I fixed my delay when I too took my machine to your girlfriends. LOL!
No seriously.... you solved your delay problem yourself when you UNPLUGGED the power cord from the back of the monitor.
My guess is that when you unplug the power cord, the monitor resets itself. It's only a temporary fix, but, IT WORKS.
1. Turn the monitor OFF
2. Unplug the power cord from the back of the monitor
3. Wait 10-15 seconds or so
4. Plug the power cord back in
5. Turn your monitor ON........DELAY ELIMINATED.
The delay returns eventually, but, I just unplug-n-replug and I'm good to go again.
Apr 07, 2008 | Gateway FPD2275W LCD Monitor
Breadmaker Won't Start
I had the same problem. Check the delay start button even though it doesn't tell you to. To get my machine to work the first time I used Menu #3 (which does not have a delay start) and it worked. Then I tried to use the dough cycle and it wouldn't go either, so I unplugged the machine, plugged it back in, went to Menu # 3 first to see the time (which was 1:50) then I checked the delay time to make sure it was also set at 1:50. Mine was not (it said 2:00) so I moved it down to 1:50 and it started 15 minutes later. I really don't like this 15 minute delay on this machine. I am going to try regular bread later and I will make sure that the delay time is the same as the time given for completing the loaf ( ie make sure it says 3:30 NOT 13:30. I hope this works.
Feb 09, 2008 | Black & Decker B2000 Bread Maker
Televison & Video Logo
206 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
