Question about Whirlpool SF367 Gas Kitchen Range
Unable to preheat
I have a SR379 whirlpool gas range. The burners and broiler work fine. During the preheat cycle, the gas clicks on and off never reaching the desired temp. This problem occurred after cleaning the oven then turning the gas off for a few months. After running the burners on top for a few minutes (in case there was air in the line) the preheat cycle worked, but the problem reoccurred again later that day. The sensor on top is clean without residue. I just can't pinpoint the issue. Any suggestions?
    Scholar:
  • 146 Answers
You need to replace the temp. sensor. It's not reading correctly. These occasionally go when you use the self clean as the range gets up as high as 900 degrees. Replace it and it will solve the problem
Posted on Dec 21, 2007
SOURCE:
Wfg361lvs oven clicks 1 times, lights and then clicks three more times and turns off.
manually check the burner and the gas jet area for blockage that would prevent lightup.. the safety is kicking in to prevent gas explosion..
Jan 12, 2014 | Whirlpool WFG361LVS Stainless Steel Gas...
Gas oven heats up to proper temperature and then quits heating.
It sounds like you may have a Whirlpool gas range. If so it is more that likely the burner assembly itself. The electrode attached to the burner gets to where it will light during the preheat but then once it starts to cycle the spark module tries three times to light the burner and then shuts down. the burner assembly comes as one unit with the electrode attached.
Nov 28, 2013 | Ovens
When i turn on bake it goes to preheat but nothing happens. the broiler and top burners work fine
If a gas range, you have a defective ignitor,
If electric, you have a burnt out back element
Jul 29, 2010 | Frigidaire FGFL79GC Stainless Steel...
My oven flame is yellow and orange. you can smell
open air vent on main burner. check burner orifice and pressure regulater
Dec 31, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
WHIRLPOOL SUPER CAPACITY 465 SF385PEGZ3 NO OVEN/BROILER
sounds like an issue with the spark module, altough that module tends to be really relliable.i would try removing pawer to te unit. checking the outlet for proper grounding,and replugging unit see if that works for you
Oct 25, 2008 | Whirlpool GS460 Gas Kitchen Range
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool SF367 Gas Kitchen Range Logo
296 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
