Question about Brother MFC 420CN All-In-One InkJet Printer
Cartridge not recognized
One by one, each color has been coming up close to empty, and then need to replace. The yellow said close to empty for a long time, so I went ahead and replaced it, however the read out never asked "did you replace yellow?" and it continues to say yellow is close to empty. I ran the cleaner a few times to see if that would fix it. Then today, it said the yellow ran out, so I opened the machine and reinstalled the yellow. Then the read out showed black is close to empty, so I reinstalled it (because it's not close to empty) and now the read out shows "No Cartridge" and is totally disabled. Any ideas?
    Novelist:
    Champion:
  • 244 Answers
Try to put hot water in each cartridge install, not so hot but normal hot that can disolve hard liquid component. When an inks happens not used more that 3 months it will become hard that might be possible the printer would not able to get the specific color because the cartridge getting problem.
****NOTE****
Make it sure the bottom part of the cartridge will not filled hot water where you can see the circuit outside, so make it sure only the sides of the cartridge filled with hot water.
Then make it sure after filling water you need to use dry cloth to make it dry before putting back again to your printer head.
Hope this will be helpful.
Posted on Nov 29, 2007
  • Cheater Cheater Nov 29, 2007
    Please let me know if you run the same problem.
SOURCE:
Where do the ink cartriges on a brother mfc 5460cn fo
Your machine is equipped with an ink dot
counter. The ink dot counter automatically
monitors the level of ink in each of the 4
cartridges. When the machine detects an ink
cartridge is running out of ink, the machine
will tell you with a message on the LCD.
The LCD will tell you which ink cartridge is low
or needs replacing. Be sure to follow the LCD
prompts to replace the ink cartridges in the
correct order.
Even though the machine tells you that an ink
cartridge is empty, there will be a small
amount of ink left in the ink cartridge. It is
necessary to keep some ink in the ink
cartridge to prevent air from drying out and
damaging the print head assembly.
a Open the ink cartridge cover.
If one or more ink cartridges are empty,
for example Black, the LCD shows
Ink Empty Black and
Replace Ink.
b Pull the lock release lever down and
take out the ink cartridge for the color
shown on the LCD.
c Open the new ink cartridge bag for the
color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1).
Note
If the protective yellow caps come off
when you open the bag, the cartridge will
not be damaged.
e Each color has its own correct position.
Insert the ink cartridge in the direction of
the arrow on the label.
f Lift each lock release lever and push it
until it clicks, and then close the ink
cartridge cover.
g If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example,
Did You Change Blck?) For each
new cartridge you installed, press 1
(Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge
you installed is not a brand new one, be
sure to press 2 (No).
If you wait until the LCD shows
Near Empty and Ink Empty, the
machine will automatically.
Find this on page 113 of the manual:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002135/cv_mfc5460_usaeng_usr_a.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 04, 2010 | Brother MFC-5460CN All-In-One InkJet...
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
Replacing a cartridge
Title:
I replaced my ink cartridge, but the LCD is still displaying "Ink Empty". What can I do?
Description: This is typically caused by an incorrect selection made during the LCD prompting after a cartridge is replaced. When an ink cartridge(s) is replaced, the LCD will ask, "Have you removed Blck? 1 Yes 2 No". This question will be asked for ALL 4 colors in sequence, regardless if the color was replaced. If "1 Yes" is NOT selected for the color(s) that was replaced, the LCD will return to "Ink Empty". Do the following to clear the message:
  1. Pull the scanner cover release lever located below the control panel and lift the top cover.
  1. After 15 seconds, re-close the top cover and then re-close the control panel cover.
  2. The LCD will then display Have you removed Blck? 1 Yes 2 No.
    The LCD will display this question for ALL 4 colors (not just the ones replaced). BE SURE to select 1 YES for each ink cartridge that was replaced.
    If 1 Yes is selected, the LCD will then display Change to new (color)? 1 Yes 2 No. Again, BE SURE to select 1 YES.
Note "Change to new (color)?" will only appear if 1 Yes is selected for "Have you removed (color)?" If 2 NO is selected for the "removed" question, the LCD will then move on to the question for the next color.
Oct 11, 2009 | HP Photosmart 3310 Printer
Brother IntelliFAX 1840C says to change yell even though its full
Your machine did not recognize the new cartridge. Remove the yellow, count to 10 then replace it. The machine will ask "did you change the color yellow?" Select yes by dialing "1" - if after the cleaning cycle "near empty" still appears, you need to contact Brother for repairs. You can safely use the machine until "INK EMPTY" appears.
Mar 30, 2009 | Brother IntelliFAX 1840C Plain Paper...
New yellow ink cartridge not being recognized
check to see if you removed the tape and that its seated all the way down
Nov 14, 2008 | Brother DCP-110C All-In-One InkJet Printer
Yes. Unplug machine from power. Wait 5 minutes. open scanner and take all the carts out. close scanner. plug machine to power again. machine will do the start up cleaning. Machine demands carts. insert NEW carts and give the answer in case you are asked by machine.
Do only change the carts when machine stopps for EMPTY cart. As long as it shows Nearly Empty everything is alright.
The machine has a drop counter and counts the ink drops down to zero when the flag is raised within the (nearly) empty carts. In case you take them out at that moment and reinsert again the ink inside will splash and raise the flag again. Control logic will be in trouble....
Nov 29, 2007 | Brother MFC 420CN All-In-One InkJet...
Won't recognize new cartridge
see here: http://www.fixya.com/support/t192382-near_empty_yellow
Sep 03, 2007 | Brother MFC-5440CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
50 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
