Question about LG DLE2532W Electric Dryer
This dryer STINKS
This heavy duty dryer requires that you reduce your load size in order for the clothes to dry before several days have passed. Not very heavy duty, I would say.
From the first week, I have been complaining about what a lousy lint trap this dryer has...clothes take DAYS to dry. I ALWAYS have to vacuum lint out of the bottom. THIS MORNING the dryer was on fire....you know why?
Because the lint trap is so lousy. It catches nothing. The lint was so built up on the INSIDE of the machine under the barrel and around the back, (Not the exhaust vent) that it caught fire. I had to run water through the back and bottom of this very expensive machine which I treated myself to because of our large family. Looks like less than 3 years later, I am out of a dryer again.
My last dryer, a cheap Whirpool gas dryer, lived for over 10 years before we had to buy a new switch, and then it lived again. ONCE I had to open the back of the machine and get the lint out. How is "Life Good" when the machine requires so much care? This machine stinks....it is a waste of money.
GG
Wow, a lot of really great information. Thank you so much. I am going to rate your answer helpful because it will take some time to know if lg will fix the problem. I really thought this was a loss, but even if it is, it is good to know for the next time. You gave me a lot information I would not have considered. Thank you.
Posted on Jan 03, 2008
  • 36 Answers
Most of the time this problem is caused by a vent restiction or mashed vent behind the drier what i tell my customers is to run 4' pvc plastic pipe from the outside hood under the house then use a90 degree elbow to come up through the floor and a small piece of metal flex vent and clamp for the final connection you'll never have a vent problem again i know how you feel and im not saying your not right just giving tech advice so you don't have same promb with new drier im a real svc tech and im concerned with you also call lgs cust relations people not cust service cust relations be nice say you didn't think lg was like this and you don't know if you just got a bad drier or what tell the whole story fire and all don't mention pile up of lint they want you happy with there products and most of the time will help some times even give you a new drier you got nothing to lose by trying all appliance mfg are afraid of the fire word worth a try do it right might get a new drier but do your vent before inst any time it takes more than an hour to dry clothes ita a washer promblem clothes too wet or a vent promblem sorry for you promblem just trying to help
Posted on Dec 29, 2007
SOURCE:
The beep that signals load is done sounds prematurely for about a minute ,the dryer continues until load is dry then shuts off
On this dryer each of the seven automatic cycles listed on your machine perform different functions based on fabrics, load size or variables. In essence the first four settings (Heavy Duty to Delicate) relate to your desired drying temperatures of high, medium, low or extra-low respectively. The moisture level of the load is determined by the dryer's sensor system and the machine will set the drying time to an optimal level.
Whirlpool added a WRINKLE FREE feature or what one might describe as an extended intermittent tumbling time. This added cycle helps reduce wrinkling when you may not be able to unload the dryer immediately after the end of the cycle when the buzzer goes off. Starting this setting is a simple one button operation at the control panel. TheWrinkle Shield™ Plus Feature is preset to on during the permanent press cycle.
Jan 30, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Duet Sport Dryer front load leaks water underneath the dryer when drying heavy duty clothes
The clothes then are too wet for the heat to evaporate. Spin extra time to get rid of as much water as possible before putting them in dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Dryer not heating very hot. need to run two cycles to dry
Dryer is not drying properly, In order to resolve try following things.
  • Check the exhaust hood outside the house, does it open and close freely, Clean the lint filter and exhaust duct.
  • Do not overload, 1 wash load = 1 dryer load. Sort heavy items from lightweight items.
  • Large, bulky items like blankets or comforters may require repositioning to ensure even drying.
  • Check the washer to be sure it is draining properly to extract water from the load.
  • Clothes load is too small to tumble properly. Add a few towels.
I hope this will solve your problem.
Good luck and have a nice day.
Jul 04, 2010 | Frigidaire GLGQ332A Gas Dryer
SETTINGS
check the hi-limit switch on the element case or the cycling switch on the motor blower housing,they get weak and cut out too soon and dont keep element hot long enough do dry clothes properly
Apr 11, 2010 | Frigidaire Electric Dryer
We have a lg dryer and it takes very long to dry clothes, I have checked out the vents and still does the the same,please give advise thank you
  1. Separate heavy weight items from light weight items when creating loads. Heavy fabrics take longer to dry because they tend to retain more moisture. To help reduce and maintain more consistent drying times for large and heavy fabrics, separate these items into smaller loads of a consistent size.
  2. Use the appropriate control settings for the type of load you are drying.
  3. Please confirm that the lint filter is clean prior to each new load of laundry.
  4. Divide your larger load into a number of smaller loads.
  5. If you are only drying a handful of items, add a few extra pieces to help ensure proper tumbling action.
  6. Confirm that the exhaust venting ductwork is properly configured. Confirm that the venting is free of obstructions. Confirm that the outside wall dampers are moving freely, that the dampers are not pushed in, and that nothing has been set against the dampers.
Oct 23, 2009 | LG DLG5988 Gas Dryer
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
LG DLE2532W Electric Dryer Logo
454 people viewed this question
Top LG Dryers Experts
jimorris77
Craig Butler
Craig Butler
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
