Red vertical line.
I have a HP flat panel 25" monitor with a annoying red thin vertical line running down it, any solutions?
  • Anonymous Nov 29, 2007
    mypc will not change color backroundin the monitor.
    Sergeant:
  • 264 Answers
I will give you a small step through which you would be able to know whether its a hardware or its a software issue.
You need to log in to the BIOS. Do not change anything in the BOIS just check whether you have that red line in the BIOS.
If you see the line while you are in the BIOS, that means its a hardware problem and you need to contact the manufacturer (In this case HP ). You should get a replacement if its under warranty.
If you do not see the red line in the BIOS than it is a software issue and you need to start with reinstalling the Display drivers.
Note : - Steps to go to BIOS. ( Dont change anything in BIOS )
Turn off the computer
As soon as you turn it on start tapping the key "F2". ( "Del" in some brands).
Hope that will give you a good insight.
Sammy
Posted on Nov 29, 2007
SOURCE:
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
There is a vertical red line that runs down the screen on our Sanyo TV. It is just a thin line but it is annoying because you know it is there. Any suggestions?
thin lines are associated with the connection of the pixels on the screen in the grid. If its under warranty get it fixed before expiry as its not a cheap fix.
Red lines are not convergence problems they are component problems so you cant adjust it out
Sep 13, 2009 | Sanyo DP26746 26 in. LCD Television
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
I have a thin vertical line about 9"from left side runs top to b
either a bad buffer pcb or display panel, 12 month warranty call panasonic quick
Aug 08, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Desktop computer monitor (flat screen) has a thin red vertical li
Detach the monitor from the cpu and turn it on. If the same vertical line appears then take it to the repair centre.
Dec 17, 2008 | IBM NetVista PC Desktop
HP w1907
This sounds like a digital problem. If the monitor is still in warranty, return it for exchange or repair.
Dan
Aug 01, 2008 | HP 22" Widescreen Flat Panel TFT LCD HD...
Thin Vertical Stripes
THESE ARE DEAD PIXEL LINES IN DISPLAY REALLY NO FIX
Jan 23, 2008 | IBM 2704hb7 (Black) 19 in. Flat Panel LCD...
Small annoyance with HP P1100 monitor. Slightly darker vertical lines.
Sounds like dried out electrolytic caps. How old is the monitor ?
Dec 19, 2006 | HP P1100 21" CRT Monitor
Computers & Internet Logo
108 people viewed this question
Ekse
Alun Cox
