Question about Ricoh 6513 Copier
Minolta CF900 error code C0030
Hello...I'm having a problem with my copier...I'm getting the error code C0030...can anyone hepl me please :-)
Good mournigg
i need help for di 550 minolta the code come is 1808
and the priner not work .
ean to cave order in comuter is going to printer .but nothing paper come
toner2book@hotmail.com
Posted on Apr 30, 2008
    Problem Solver:
  • 7 Answers
This is not a ricoh,, re code this issue as minolta nd you will get a ready answer...it is in the back of he usermanual
Posted on Feb 15, 2008
Error c0042
je veux bien savoire quelle genre des erreur
merci
amik85@hotmail.com
Apr 16, 2009 | Office Equipment & Supplies
Minolta CF900
try and locate botton called ACCESS.on the OP Panel should be pressed after you enter you access code
hope that help ...if not try the START BOTTON
Jan 11, 2009 | Konica Minolta DiALTA CF910 Copier
Minolta CF900 code C3250
CAUSE: Worn mylar.
SOLUTION: Refer to bulletin 3135 which pertains to the transfer drum joint Mylar.
If you can find a Konica Minolta dealership that can get the part or have tech come out and look at it A VETERAN (NOT MILITARY)Tech you have legacy Minolta now Konica Minolta, CF was first generation color. The mylar is dealing with the Transfer drum the big clear drum next to the drum.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 20, 2008 | Minolta Office Equipment & Supplies
Description:
Intermittent C-3250, C-0210, or C-0230 codes occur during pre-drive.
Solution:
CAUSE: Worn mylar.
SOLUTION: Refers to the transfer drum joint Mylar.
SOLUTION: Replace the mylar (P/N 1144-4511-02)
hope that help
Oct 20, 2008 | Minolta EP1031/1031F CS/PRO Copier
Minolta cf900
High Voltage discharge to a electrical holder, there was cover developed for this problem, i don't know if KM has parts for this legacy machine
Aug 24, 2008 | Office Equipment & Supplies
Cf911 error code c0030
Developing Drive motor failure to turn, have you recently had the developer changed and or the motor may have burned out. If developer was change check installation procedures
Jul 06, 2008 | Minolta EP1031/1031F CS/PRO Copier
Neosca63
Subject:
C0030 code is displayed and will not reset. The C0030 is referenced to the developer drive motor for the 4 developer units. developr motor is binding
hope that helps
Jul 04, 2008 | Konica Minolta DiALTA CF910 Copier
Minolta CF900 error C0660
There should be a lamp regulator PCB check the fuse on it. Also, if you move the scanner out of HP will it find HP again? Also, how offten does it show up scines the last time?
Feb 20, 2008 | Office Equipment & Supplies
you may need to replace parts.
BUT check the oporation of the unit FIRST. LOOK BINDING IN THE DRIVE UNIT
HOPE THAT HELP
Feb 15, 2008 | Minolta EP1031/1031F CS/PRO Copier
Minolta CF900 Photocopier
CODE C0900, DOES NOT PASS COPY, FIERY FRONT COVER BROKEN OFF AND VERY DIRTY, also you may want to try and look at the 3rd drawer lift perheps there's somthing blocking it
Aug 29, 2007 | Konica Minolta DiALTA CF910 Copier
Ricoh 6513 Copier Logo
193 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
