Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Maytag Neptune Stacked unit door leaks
I have a Neptune stacked unit. When the wash cycle reaches stage 3 (sounds like it is filling tub to rinse) the door starts to leak. I assume it is overfilling at this stage as the door does not leak any other time. If I manually move the dial to the next stage, the leak stops. How to fix???/
  • 3 more comments
  • macuserjp Jan 18, 2008
    Ended up that the problem was a stopped up line from the fabric softner dispenser to the drain.
    $78 repair from local company.
  • Anonymous Apr 18, 2008
    why does my maytag neptune washer/dryer fabric softner fills with water now and now it overflows and leaks out of my door.
  • topmowry Jun 20, 2008
    If it is the line from the fabric softener to the drain, how do I fix it myself?
  • Anonymous Nov 08, 2008
    door leak
  • Anonymous Mar 30, 2014
    leeks fom the front door when is filling for rinses or start rinsing
    Scholar:
  • 196 Answers
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Posted on Jan 15, 2008
Put detergent
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 14 years for me.
Jan 14, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
My stacked Maytag front loader leaks out through the door when the fabric softener dispenser is being filled (2nd rinse cycle only). Any help?
The second rinse is when the softener cup is being flushed. Remove the dispenser and clean and inspect the housing to be sure no softener is gumming up the holes and blocking the water flow into the machine.
Jun 11, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Very loud spin cycle
It sounds like the bearings have gone out in the tub. The major cause of this is using powder soap. There is nothing you can do but replace the rear outer tub. This is a costly fix but maybe worth it for a stack unit.
Jun 26, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag stack unit Model LSE7806ACE leaks
It is most likely the tub seal. Take the two phillips head screws out of the front cover located low on the cover lift forward and remove. Set the machine two low level and fill with water only no soap or clothes when unit starts agitating look at the bottom center of the clothes tub if water is leaking here then you will need to replace the tub seal and tub bearing assembly.
Apr 06, 2009 | Maytag LSE7806A Top Load Stacked...
Water won't completely drain from tub. Door seal is very moldy.
Had a simular problem. In my unit the water was not visible in the drum but you could hear it when you turned the drum by hand.  The answer as told to me by the Maytag repair man:  The machine is designed to hold the water after the cycle is complete.  As he was replacing the boot seal he suggested to just leave the door open so the seal will dry out and not mold.  This has been working for the past several years.  No mold has appeared on the new boot seal.
From another source I read that the water is left in the machine for balance.
Feb 02, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Neptune stackable washer...
You put the detergent directly on top of the clothes.
Jul 31, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Detergent goes where?
3 - Select Cycle
This is according to the owner's manual I have. Has worked for 9 years for me.
Jun 28, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Shutting off early
Check out http://www.maytagfrontloadsettlement.com. This sounds like the same problem many other Maytag customers have encountered (including me).
Dec 07, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
514 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
