Question about Irons
New rowenta effective iron that doesn't heat and steam correctly
My new rowenta effective iron is not working as it should. It doesn't heat when a light on the side is not on. My book says this light is a water indicator but I think it is a sensor of some kind. I have shaken iron , added water turned fabric dial up pluged and repluged to get it on. It has taken me as long as 5 miniutes to get it on. I don.t like it at all.
Linda s.
  • 1 more comment
  • Anonymous Dec 13, 2007
    After plugging in the iron and turning on the steamer, it doesn't seem to heat and water leaks from the bottom of the iron. The iron is not cold to the touch but you can place your hand on it for a long time without it burning you. The red indicator light is on so I know that power is getting to it.
  • salbart Aug 04, 2008
    The iron will not turn on.  It is warm to touch, but does not get hot.  I left it on and I think it turned off and will now NOT go back on but honestly, I do not know if it heated to begin with.  Thank you.
  • misslady101 Dec 15, 2008
    lndicator light comes on, but it will not heat up
Don't use distilled water-I had same problem. It was built to use regular water. Solved problem
Posted on Mar 08, 2009
My rowenta Dw9280 steam iron won,t heat up.
Failure of heating element, control, or both
Mar 14, 2018 | Rowenta Irons
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
Issues with Rowenta Steam Iron DG 05030 steam hose
Does your iron have a self cleaning feature? It sounds to me like you have calcium build up and when you squeeze the hose it displaces the "clog" just enough to allow steam through.
Nov 12, 2012 | Rowenta Steam Generator DG050 Iron
No steam is coming out i think it needs cleaning
Some irons like Rowenta have a self cleaning feature. If yours doesn't make a solution of 1/2 vinegar and 1/2 water and put it in your iron. Plug it in and allow it to heat that up. keep working your instant steam button for a while. Hopefully the vinegar will help remove the calcium build up and let it work.
Nov 11, 2012 | Irons
ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
Jul 25, 2009 | Rowenta DX6700 Iron
My rowenta effective will not heat up.
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Dec 15, 2008 | Rowenta DG5030 Iron
Irons Logo
640 people viewed this question
Top Irons Experts
Marvin
Marvin
Are you an Iron Expert? Answer questions, earn points and help others
