Question about Dynex DX-E401 Router
Set up tryinmg to set up dynex E-401. after putting ip address in browser and log on window opens, instructions say type in "admin and leave password blank. It won't go. keeps asking for password. what do i do to get around this?
  • Anonymous Dec 09, 2007
    My pc is not picking up signal to internet
No u don't leave it blank the password IS blank so u just type in admin for the user name and then type in BLANK for your password then after than u can change your password but he username remains then same.
Posted on Dec 01, 2007
SOURCE:
I have a trendnet tew-625brp, i just opened it, i can connect to it perfectly by cable howeve i want to set it up wirelessly, when i go to 192.168.10.1, i type in admin for username and password, and it...
You must complete the setup with a wired connection. Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Computers & Internet
Im looking for the wpa2 number for my dynex router
  1. On a computer that has a wired connection to the Router, open up a web browser. In the address field, type 192.168.2.1 (or the IP address you customized), then click Enter.
  2. In the menu at left, go to the wireless section and click Security.
  3. If asked to log in, enter your password or, if you have not yet set a custom password, leave this field blank. Then click, Submit.
  4. You should now see your WPA2 Configuration key in the Pre-shared key field.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
May 18, 2011 | Dynex Wireless-G Broadband Router
How do i change a password
If you don't have the current password, you will have to press the reset button located next to the power connector port. This will reset it back to factory default settings. The you can access it with your browser:
To access the Web-based management utility:
1 Open your Web browser and enter the IP address of the router into the
Location (for Netscape) or Address (for Internet Explorer) field, then press
Enter. The default IP address of the router is 192.168.0.1
For example, type 192.168.0.1
After the connection is established, the logon screen opens.
2 To log in as an administrator, enter the user name of admin and leave the
password field blank (default), then click OK. The Web management Home
screen opens.
You can download the user manual at:
http://www.retrevo.com/support/Dynex-DX-E401-Routers-manual/id/8352ag821/t/2/
Jan 15, 2011 | Dynex DX-E401 Router
I did not put a password on when i installed the d-link. how can i do that now please
a_detail.jpg Step 1 Open a web browser and enter the IP address of the router in the address bar (default is 192.168.0.1). Press Enter.
Step 2 The default username is admin and the password is blank (nothing). Click OK.
Step 3 Click the Tools tab and then click Admin to the left.
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password (blank by default), and then click Ok or Log In .
Feb 17, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I cant get the router to connect to the internet and cant get the password to work to use the set up wizard
On the back of your router press and hold the reset button for about 10 seconds.
This will reset the router to factory defaults.
Open your Web browser and enter the IP address of the router into the Web Browser. The default IP address of the router is 192.168.0.1
Jul 19, 2009 | Dynex DX-E401 Router
Password not working
Do the following: on your computer open internet explorer, in the address window type the IP of the router "example" http://192.168.2.1 your router IP should be on the bottom of the router. If not click start/run, type ipconfig at the > the router ip is listed at "default gateway".once you get to the routers logon page enter one of the following: username "leave blank" – username " admin " -or- username "admin" - password 1234 –or- leave password field blank. once logged on the router you can make your configurations. BPCS
Dec 28, 2007 | D-Link DI 514 Wireless Router (DI-514)
401 Authorization Error when accessing a Web-based Utility
Getting the 401 Authorization Required error page means that you tried to access a Setup page and entered an invalid password three (3) times. To reset the password, the device must be reset to factory default settings. Resetting the device: 1. Hold in the Reset button (usually located on the front or back panel) for 30 seconds. 2. Unplug the power cord to the device and wait for 1 minute. 3. Plug the power cord back into the device. 4. This will restore the device's default settings, which includes a default password of admin. 5. You can now try to access the Setup page again. Accessing the Setup Page: Open a Web Browser (either Internet Explorer or Netscape). Type the IP Address of the device into the Address Bar and press [Enter]. 1. The User Name and Password Prompt will appear. 2. Leave the User Name Field blank. 3. Type in the Router?s Password, admin, (the default Password). 4. Click OK or press the [Enter] key. If the device was reset to factory settings, the password of admin should be valid and the Setup page should load. If not, repeat steps to reset the device.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Feb 16, 2006 | Linksys EtherFast Cable/DSL VPN Router...
Configure DMZ Host
enter username admin and password blank (nothing), i got 401 Unauthorized messege 3 times reset the routher DI-524
Feb 16, 2006 | D-Link DI-704P Router
Computers & Internet Logo
143 people viewed this question
Top Dynex Computers & Internet Experts
gggg
Prashant M
Prashant M
Mike
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
