Question about Zyxel Prestige 660R Router (91004397002)
ZyXEL Prestige 660HW-T1
I tried entering the default IP address to enable me to secure my connection. After entering the default 192.168.xx.x the screen just said done. I trie hitting the resen button on my modem and still come up with the same. I used the default UN and PW as well. How do I access the router to make changes?
  • Anonymous Mar 28, 2014
    Unable to install Zyxel Prestige 660HW without CD
  • 4 Answers
On the reverse of the router is a recessed button. Use a pen or pin/paperclip to push this in (while the router is powered on) for around 10 seconds. All the lights should flash off and then start to come back on. This will restore the factory settings, default IP 192.168.1.1, system password 1234.
If the IP still does not work, click stat/run and type CMD. Hit OK, when you get the black screen, type 'ipconfig' (without quotation marks) and press enter. Make a note of the 'default gateway', and type that into Internet Explorer. If this doesn't work, reply to this. Ta.
Hope this helps.
Matt.
Posted on Dec 17, 2007
  • 556 Answers
Did you buy this device used or get it second hand from a friend?
Posted on Dec 06, 2007
  • david Dec 06, 2007
    If used, borrowed,etc it may not have the default configuration and we may have to investigate resetting the device to allow access. The user guide could assist you, check on the manufacturer's website for information.
Browser wont access http://192.168.1.1/
Confirm that you are connected to the router via a ethernet cable, unless you specifically configured wireless management within the router.
Confirm that you are being assigned an ip on the computer you are trying to configure from. (At a cmd prompt type "ipconfig". You should have an address 192.168.1.x if in fact 192.168.1.1 is your default gateway. Also if this router was configured for secure only management you will need to connect via https://192.168.1.1
Dec 08, 2011 | Zyxel Prestige 660HW Wireless Router...
My ex partner set up my internet access using a Zyxel router P-660HW-T1. Now my daughter has purchased a laptop and wants to connect to the internet. Unfortunately, he didn't tell me the security key...
There is a reset button on the back of the router. You have to press it in for about 10 seconds. (While the router is on) This will reset the router to default settings. You will lose all security, and your network will be "Open". You will then have to refer back to the guide in order to setup your network security, and create a new password.
Here is a link to the guide.
ftp://ftp.zyxel.com/P-660HW-T1/user_guide/P-660HW-T1_3.40.pdf
Sep 04, 2011 | Zyxel P660HW-D1 Router
I have a Zyxel P660HW-T1 v2 and when trying to use laptop wirelessly, the internet connection keeps dropping. While connected to the router by ethernet cable, internet is fine. All was working fine until...
For that you need to change wireless channel type in router. You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless->wireless channel type to 3 or 6 or 11 then save settings and restart router. . Let me know if you need further assistance. Thanks for using FixYa.
Jun 22, 2011 | Zyxel Prestige 660HW Wireless Router...
Recently, I bought ZyXEL Prestige 660HW-T1 router, it works fine, but sometimes GREEN Power (PWR/SYS) light changes to ORANGE color and lights for a few seconds and change backs to Green. Is it Ok? or...
You need to reset your router to defaults then configure it again then it will work fine.
For that press RESET button for 10 seconds it is in back side of router.
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Jun 02, 2010 | Zyxel Prestige 660HW Wireless Router...
I cant log in to my zyxel!(zyxel ies 1248) cos of someone change the IP address so how can i reset default?
See the attached manual and look up page 42 where is shows how to reset your router to the default settings. The default ip is 192.168.1.1.
the link is: ftp://ftp.zyxel.com/P-660HW-D1_v2/user_guide/P-660HW-D1%20v2_3.40_Ed1.pdf
If this solves your problem, leave feedback please.
Feb 05, 2010 | Zyxel Prestige 660R Router (P660R)
I can not connect to people on my ps3 because my NAT is on strict how do i change it?
disable the firewall in the router, enable UPNP, in the router open up the following port numbers for an IP address and assign that IP manually in ur PS3.
TCP:80,443,5223, 10070-10080
UDP:3478, 3479,3658, 10070
Jan 10, 2010 | Zyxel Prestige 660HW Wireless Router...
No connection via Ethernet between Zyxel P-660HW-D1 and PC
Hi Friend,
Before Connecting your internet we must check in ur system.
1.Go to Start---->Run------>type cmd----->in the black screen type ping 127.0.0.1
2.check wither its getting reply or request
3.If u are getting reply then ur system is perfect i.e., your NIC Card is installed properly.
4.check wither any proxy is enabled in the LAN settings.
go to browser--->tools---->internet options(Options)----->Connection--->Lan Setting--->there should noy be any tick mark in the boxes
Now we can check the connectivity,
1.Connect the PC from the Router Lan Port and the modem connectivity to the Wan Port of the Router.
2.Assign the Ip address as obtain ip address automatically
Right click networkplaces--->properties--->Lan Connection Properties---->double click the internet protocol(Tcp/IP).In the next box u must select the Obtain Ip address automatically
3.Now u switch on the modem after 30 sec switch on the Router.
4. Launch your web browser.
5 Type "192.168.1.1" as the URL.
6For administrator access enter the default admin password 1234 to configure the wizards
and the advanced features.
7 Click Login to proceed to a screen asking you to change your password or click Cancel
to revert to the default password.
8 If you entered the admin password, it is highly recommended you change the default
admin password! Enter a new password between 1 and 30 characters, retype it to
9.Then u can configure the ip address
Regards,
Ayyasam
May 29, 2009 | Zyxel P660HW-D1 Router
Zyxel P 660HW T1 how to apply DMZ mode for a CCTV
Network - NAT - Port Forwarding - Default Server, Put the IP of your CCTV Hardware/PC
This IP will accept connection on all ports.
I never did this yet so any success please reply.
Mar 26, 2009 | Zyxel Prestige 660HW Wireless Router...
Zyxel Prestige 660R Router (91004397002) Logo
4,488 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
