Question about Samsung Digimax V5 Digital Camera
No show! camera turns on-beeps three times and then turns off
  • Mimisp Dec 03, 2007
    thanks so much...not quite the easy fix solution that I was hoping for, but anyway!!!!
  • Anonymous Dec 09, 2007
    Go to turn on the camera it beeps 3 times then shuts off. and the lens is extendedwhat can I do to fix this. thanks jauger@qualityprint.ca
    Genius:
  • 2,985 Answers
Contact Samsung support this is a major malfunction.
Posted on Nov 30, 2007
SOURCE: Camera turns on for three seconds, beeps three times, then stops.
It's the optical zoom. The motor that pushes it in and out died.
Posted on Oct 21, 2007
SOURCE: Samsung camera power-on problem and beeping
Camera got dropped..had the same problem here, looked after reading this and the smallest part of the telescoping lense was just a little tilted. Gently moved it out and popped it back, works fine now. Another thank you for the tip!
Posted on Dec 24, 2007
  • 3 Answers
SOURCE: samsung s630 camera
Finallly sent it in for repair - two times! First time, it took several weeks before I got it back. When it arrived it still would not work, so it had to be sent in again. Then they tell me I broke the camera myself so if they are to send it back (unrepaired) I would have to pay them $50. At this time, paying shipping costs back and forth I figured it wouldnt be cost effective. All together it cost me a total of $200 for 15 pictures taken with the first battery set, which after it would do nothing but beep three times. Some people mention the cause being that they dropped it, but I never did, it was like that straight out of the box.
Posted on Jun 24, 2008
  • 65 Answers
SOURCE: beeps three times and shuts off
The lens is jammed. It requires manually resetting. If you in the U.K I can help you out. email me at kiddo242@hotmail.com
Posted on Aug 09, 2009
  • 3 Answers
SOURCE: three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Posted on Aug 21, 2009
When i turn my camera on It shows the welcome
Try inserting new batteries or fully charged batteries.
Jul 31, 2010 | Polaroid I1037 Digital Camera
Insignia camera turns off with three beeps
The camera is trying to turn on, but either the lens is stuck, causing an overload in an effort to turn the motor that, through gears, extends the lens. That's a common problem, and the 2nd most common problem is that the batteries are not holding enough charge to drive the motor, contacts are dirty, things like that. There are 2 excellent web blogs that detail the problems, and what you can check and try. Here they are:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Good luck, and hope this helps.
Jul 13, 2010 | Cameras
Three beeps when i try to turn it on
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
White screen
Mine too!
It beeped three times, then went black. then went white and now won't do anything! ahh!
Sep 09, 2008 | Samsung Digimax S500 Digital Camera
S85 camera will not turn on just beeps three times
I figured out the fix:
Take the batteries out, put them back in and close the battery cover. Next, turn on the camera and before it can finish the three beep sequence, open up the battery cover(disconnecting the battery power). Close the battery cover (reconnecting the batteries) and switch on the camera. It may take a couple of tries, but it seems to be a "poor man's reset"
Apr 21, 2008 | Samsung Cameras
When I try to turn on, or see pictures stored, it beeps three times and shuts off
called samsung s800 have know power problems return for replacement before warranty expires or they will charge you 58 to fix
Oct 28, 2007 | Samsung Digimax S800 Digital Camera
Oct 10, 2007 | Samsung Digimax S700 Digital Camera
Samsung Digimax V5 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
