Question about Hitachi 50UX57B 50" Rear Projection Television
TV just shuts itself off after 1/2 hr to 2 hrs ...
Great picture, but this last year it just started to turn itself off after anywhere from 1/2 hr to 2 hrs rare maximum! Seems like it overheats or something? help!
  • Stu Wuu Dec 19, 2007
    I own the 50inch Hitachi television model# : 50fx18b/ serial# : v6h004891 and I have been experiencing the same problems. I turn the television on and it'll be fine for not even 15 seconds, then it will just shut itself off. I have tried to research the problem but, I'm not having much luck. Any suggestions would be greatly appreciated. Thanks!
    Novelist:
    Champion:
  • 232 Answers
Resolder the horizontal driver transformer and all of the coils that start with "L77xx" on the left side of the sweep board, there is also a jumper staple just above L7711 that must be soldered it does not have a designation number but you`ll see the solder is bad on one end, very common issue with your model.
Posted on Nov 30, 2007
SOURCE:
Why does my DLP TV turn itself off
Try replacing that lamp door switch, this has been known to cause issues in some Samsung DLPs
Contact Samsung at 1-800-627-4368 for proper part#
Oct 21, 2014 | Samsung HLP5063WX/XAA
Can anyone point me in the right direction?I have had my samsung DLP (model SP50L6HD) for 4 years. This morning my children were watching TV and the tv started turning itself on and off. I switched it...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 24, 2011 | Samsung HLM507W 50" Rear Projection HDTV
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
Tv turns on then after about 1/2 hr to 2 hrs it will shut itself off and the on blinks red 6 times and I wont be able to turn it on until 10 min later .
ONe of the power supplies is overheating
This will need professional service done.
Check the web for Sony service near you
Jan 27, 2010 | Sony KDF-42WE655 Television
My mitsubishi 52725 shuts itself off after acouple hrs
Its most likely the thermal fuse which is causing the problem. It gets up to operating temp then shuts down.
Jun 17, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Emerson EWL20D6 TV turns on and the picture goes right back off
Mine is doing the same thing. I talked with a local repair guy over the phone and he says that (obviously) something is malfunctioning in the TV and a sensor shuts it off to minimize the damage to other components. This would be ok if the TV were 20 years old (they used to last that long); however, mine is only 1 1/2 years old and Emerson couldn't give a damn that the TV is a piece of ****. Silly Mimi
Mar 25, 2009 | Emerson EWL20D6 Television
Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
TV shutting off
try this part first 5600110347 you can get it at www.vancebaldwin.com
Jan 31, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Hitachi 50UX57B 50" Rear Projection Television Logo
66 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
