Question about Bush 5693D 24" TV
Bush 22" LCD TV
I was playing around with the menus on my tv when i set the volume on hotel mode now i Cant get into factory menu to get it off Hotel Mode Volumes really quiet
  • 1 more comment
  • froody Mar 11, 2008
    i have the same problem on my dmtech tv and also can't sort it out. any suggestions anyone?
  • Anonymous Jun 11, 2008
    MENIU SERVICE ?
  • Anonymous Nov 15, 2008
    Did you manage to fix it mine is he same very annoying
  • 372 Answers
Hi.
What is the TV model number ?
Posted on Nov 29, 2007
SOURCE:
Just bought an RCA tv that came from a hotel,model # J27330BL, and trying to reset to factory defaults as it only allows certain channels to be utilized. Also, trying to get reset so I can switch to...
There's no way to reset factory default but can access service menu, Hold down menu button on front panel and press volume up and power at the same time, on the top right screen, use volume up, Press to scroll to 72, press volume up and your are in the service menu.
Aug 20, 2011 | RCA F27442 27" TV
Tip
ERROR CODE AND SERVICE MODE
Service tool modeHow to access
1. Select [SRV-TOOL] in Service Mode.
2. Press [OK] button on the remote control.
Display of SOS History
SOS History (Number of LED blinking) indication. From left side; Last SOS, before Last, three occurrence before, 2nd occurrence after shipment, 1st occurrence after shipment.
This indication except 2nd and 1st occurrence after shipment will be cleared by [Self-check indication and forced to factory shipment setting].POWER ON TIME/COUNT
Note : To display TIME/COUNT menu, highlight position, then press MUTE for (3sec).
Time : Cumulative power on time, indicated hour : minute by decimal
Count : Number of ON times by decimal
Note : This indication will not be cleared by either of the self-checks or any other command.Exit
1. Disconnect the AC cord from wall outlet.
Hotel mode
1. Purpose
Restrict a function for hotels.
2. Access command to the Hotel mode setup menu In order to display the Hotel mode setup menu, please enter the following command(within 2 second).
[TV] : Vol. [Down] + [REMOTE] : INPUT (3 times)
Then, the Hotel mode setup menu is displayed.
3. To exit the Hotel mode setup menu Disconnect AC power cord from wall outlet.
Troubleshooting Guide
Use the self-check function to test the unit.
1. Checking the IIC bus lines
2. Power LED Blinking timingCheck of the IIC bus linesHow to access
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Exit
Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
FOR MODE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE DROP DOWN MENU
on Jun 30, 2015 | Panasonic Tc-50ps14 Tv Power Supply Board...
I need the code that will tske my samsung 40" out off hotel mode
hello,
To switch off hotel ode on samsung, enter:
1. On standby press info-menu-mute-power or,
2. press mute-1-8-2
After service mode appear, Choose option block,
Fine Hotel mode, change to off.
If in option block you can't fine it, try open other block.
Good luck.
Apr 16, 2011 | Televison & Video
Tv seems to be locked, cant access the program settings has it got a hotel lock?
hi,
u can remove the lock by fallowing settings.
1. press menu button and select channel and press enter.
2. select channel manager and press enter.
3. select channel lock then press enter.
4. select off and then press enter.
ok
Dec 15, 2010 | Samsung LA22A450 22 in. LCD TV
Can not program to my tv or sat or pinneer eqp.
your tv is in hotel mode. setting menu is disabled, try these universal steps
1st power off tv
2nd power on and press a key, while power on and release key. When is the right combination, appears setting menu and change from hotel mode to normal mode.
Jan 16, 2010 | Sony KDF-E55A20 55 in. LCD Television
My tv was purchased from a hotel and the volume is 'locked' at the mid-point. how can i fix it?
you cant. these tvs are manufactured like this to keep the volume at an acceptable level so that this tv volume does not disturb the next room. Unless this tv has an audio output (red, white) to output the tv audio to an external audio source such as a surround sound system then the volume is what is. Altough a good buy a tv is from a hotel it comes with limitations. Take it to pawn shop to sell then buy another tv not from a hotel.
Aug 15, 2009 | Zenith B36A24Z 36" TV
Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Jul 28, 2009 | Akai Televison & Video
CANNOT RETUNE THIS TV BUSH TV DVD COMBO LY2211WCW
Press menu button then press 7935, if like me you bought a display model it will be set to hotel mode, this hides all the menus, once accessed switch hotel mode off, job done x
Jun 11, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Hotel lock, not available but im sure there is another way
Not all sets have a hotel lock.....key in for a google search on the model and get a free download of the user manual.
May 20, 2009 | Sansui HDLCD3210 32 in. LCD TV
Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
Oct 17, 2007 | Philips 36PT41B TV
Bush 5693D 24" TV Logo
518 people viewed this question
Top Bush Televison & Video Experts
Vitally Alcher
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
