Internet disconnect I have a self built PC and previously thought it was my internet provider causing my PC to constantly disconnect when under any download pressure or fast surfing between pages but after moving to a new provider I found this is still happening. More if anything. Can you help me with this issue. I am lead to believe this may be a driver issue
  • 3 more comments
  • darkwillow Nov 30, 2007
    Wasnt sure what this was at first till I looked it up. I downloaded a program called Dr TCP. This apparently controls my MTU. I tried on 1500 and also on 1492 but it never made any difference to the issue
  • Anonymous Nov 30, 2007
    oops said it 3 times, sorry :)
  • Anonymous Jan 10, 2008
    ok actually went out and brought a network card which has helped. I have narrowed the problem down. My motherboard has some kind of safety cut-off which makes my internet fail when downloading. By installing a seperate nework card I have bypasses this safety featue and now when under pressure my PC goes into a blue screen error and freezes or restarts
  • 58 Answers
It could be a problem with your router. You can try to change the MTU value. Mine is at 1492.
Posted on Nov 29, 2007
  • goovy75 Dec 01, 2007
    I also had this problem and i solved it to buy a cheap pci 10/100 network card. The problem was the onboard broadcom network controller from my asus p4g8x deluxe motherboard.
    does your modem also has wireless. maybe you can try wireless
Do I have a dying alternator or an electrical issue?
could still be alternater voltagt regalators are built in the alternater cause when you rev motor up ur alternater will put out little more volts your probly at low end of life on it.thats my that thought week alternater
Jun 03, 2014 | 1995 Nissan Pathfinder
I have had constant disconnection from internet for the past 6 months, I even purchase a new modem/router (2Wire from AT&T) and in addition, my son has XBox Live. The internet goes out whether he is...
With your problem its related to your internet service provider that can be a problem from their end which is causing your constant disconnection, and your ISP should do some checking on your line..
Hope that helps.....
Aug 14, 2008 | Computers & Internet
Internet keeps disconnecting - Internet disconnect
Having intermittent internet disconnects? There could be a couple of causes for this issue. Your internet could be degraded when it gets to your house causing disconnects. You will have to contact your Internet Service Provider in order to have them resolve this issue. Normally, they will replace splitters and may even replace lines outside of your house. You could also be having problems with the modem directly. The may replace this. If you have a modem that you bought that was not provided by your ISP, you can try to update the firmware on the modem.
If using a modem
I recommend you unplug the router, plug the computer directly in the modem and see if you still have the problem. If you still have the problem then you know it is just the modem. If the problem resolves itself then you know the most likely culprit is the router.
I would also recommend that you update your router firmware as well. Do a google search for the brand name of the router and go to the companies website, look in the support/downloads section for updated software.
--If possible, try a different Ethernet port on your router. You may have a bad port.
--Take out and reinsert all Ethernet cables on your network. Loose cables can cause disconnects.
--If possible, replace the Ethernet cables. Bad cables can cause this.
Lastly, you could be having an issue with the Network card(NIC) on your computer. Network cards are either built into the modem or external(a card you insert into the motherboard). Using the process of elimination and the steps above, you can hopefully narrow down the problem to one specific component of your network.
Internet disconnecting, internet keeps disconnecting, internet disconnects, internet not staying on, internet shuts off, internet keeps shutting off
on Jun 14, 2011 | Computers & Internet
I log into facebook and keep getting a message internet not able to connect operation aborted but no problems connecting to anything else. been happening for days now
This is probably due to your internet connecting then disconnecting due to poor connection, which is especially possible if you are using the internet over a WiFi connection. This would not cause a problem on most websites because the internet is built to handle unsteady connections, but Facebook has built there own software to not connect if this happens.
The best solution would be, if you are using WiFi, to get closer to the router or to upgrade your router. If you are not, you should contact your internet provider.
Feb 27, 2011 | Facebook Social Network
Randomly disconnection
That seems to you ISP (Internet Service Provider) issue
Mar 10, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
Need driver for built in wireless on RM cl51-14 laptop
just install your DSL internet providers SOFTWARE and maybe it fix by it self. ok
Dec 29, 2009 | ASI CL51-15 Notebook
I have china mobile model. n82i .internet problem
download the internet setting provided by your network provider also download the setting for nokia handsets those are the only handset model of nokia recognized by your network service provider.
Sep 10, 2009 | Siemens M56 Earbud Hands Free Headset
Constantly getting diconnected from a site
Do you use "Acer Tech - Empowering Technology Framework"? that includes "eNet" management??
If so, uninstall eNet, and your internet should be ok.
Mar 29, 2009 | Acer Aspire 5315 Notebook
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
